Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Verify your fans are for the CPU and case are moving. You can remove the Pc cover and turn on the Pc. Watch the cooling fan on top of your CPU heat sink, it should begin spinning when you turn on your PC. If it doesn't then with the PC unplugged, make sure the connector for the fan is seated properly. From behind the PC you should be able to feel the Power Supply cooling fan moving air. Either of these could cause your PC to over heat and shut down.
restart and tap F8 key, if loads to repair your computer/Advanced boot option, select safe mode using the down arrow key and log in to your account, create a backup of all the data on a removable storage device.
Insert System disk and run a system recovery to the original fcty setting, if backup done, restore from the removable storage device.
Hey there, sounds like it is stuck in your drive? Simple, there is a small hole in the front of the drive, put a paperclip in there to push the drawer out
It may be a virus or trogan problem. DO clear the Internet explorer cache and browsing history. remove all unwanted programs using add remove programs. please reply to me if u can solve with thos solutions
