Question about Hoover F5837-900 SteamVac Supreme Wet/Dry Vacuum
Broken hose The hose on my Hoover F5837-900 Steam vac Supreme broke away from the coupler on the bottom of the unit - under/behind the recovery tank (solution tube is till attached). It might have gotten pinched in there a couple times. Problem - it was glued in the coupler really well, and I cannot get the whole thing out - hose will be too short anyway - is there a way to fix this or a part I can order instead??
  • Coop013 Jul 21, 2008
    Thanks very much for the information!
    President:
  • 1,673 Answers
You will have to replace the complete hose asm, part # 90001337
Posted on Jul 20, 2008
Hoover steam vac maxx 77 motor suddenly not running?? its almost new
Should still be in warranty. Read the warranty and get in touch with Hoover.
May 07, 2015 | Hoover Vacuums
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I own a hoover steam vac model # F5915900 inside the recovery tank the seal broke. Where can I buy a new rubber seal?
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
Mar 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac has no suction, blowing air from middle of bottom
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac doesn't pick up all cleaning soluation when cleaning carpet? I have clean both filters
Please look to make sure the rubber ring gasket is still in place under the recovery tank. The tube on the bottom of the recovery tank must seal to the rubber ring to get suction.
Dec 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Can't figure out how to get my hoover runabout steam vac to pick up
Also be sure the recovery tank lid is properly aligned to the recovery tank.
If you are unsure about operation, please reference the following manual:
http://www.hoover.com/pdfs/manuals/F7431900.pdf
Oct 05, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam vac not sucking water back up i have super wet floors and no water in recovery tank
I think it is the gasket on top and bottom of the plastic chanel that takes the water up to the dirty water holding tank , Part of the rubber gasket is missing on both the top and bottom. This will alow
air to come in and thus you loose the suction to empty the water into the dirty water bin. My unit is hoover steam vac model F60220-900. I need to know where to get the gaskets.
Aug 28, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover F5837-900 SteamVac Supreme Wet/Dry Vacuum Logo
136 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
