Question about Danby DKC645BLS Compact Beverage Cooler
Buzzing noise from DKC645BLS
My unit has recently started making a buzzing noise from the right hand side by the top by some sensor. When I tap on the outside of the unit it quits making the noise. The unit cools fine regardless of the noise, it's just annoying. Do you have any ideas?
Brad.
  • 1 more comment
  • sid288 Sep 18, 2008
    The small fan on the inside of the unit is making a loud buzzing noise when running. Can I replace this fan myself and where can I get parts?
  • Anonymous Nov 10, 2008
    I am running into the same problem. I know for certain that my buzzing noize IS the fan on the inside (upper right) and was wondering where to go to find a replacement. Any help would be greatly appreciated.
    Thanks to all.
  • Strugglewith Apr 23, 2009
    It sounds like i have the same problem, it sounds similar to a leaf blower being used next door. Is that the same sound you guys are hearing?
  • 4 Answers
It's the fan that moves the air around inside to aid in circulation. Call danby and ask to buy it. It shpuldn't be very expensive at all.
1-800-263-2629
Posted on Aug 07, 2009
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
My Quartz heater is making a buzzing noise, what could that be?
The buzzing noise was coming from the back of hte unit on the lower left side. It may have been a "stuck" switch & tapping on the side seemed to fix it.
Nov 25, 2009 | Marvin Quartz Radiant Heater
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
I have recently acquired a old Denon AVR3801 Home cinema Receiver. I have plugged it all up and switched it on, but although the system seems to work quite nicely, the amp itself makes a buzzing/humming...
The solution of leaving the thing on all the time would certainly work, but most of the time a buzzing sound inside a relatively robust audio amplifier is being caused by the huge transformer coil in the thing. Or wires that are in close proximity thereto.
In some ways, you're blessed that the buzzing is coming from the unit itself, and not through the loudspeakers.
Mar 06, 2009 | Denon AVR-3801 Receiver
Buzzing sound
Re:- the buzzing behind the dash:-
Its tiny a fan which carries on running in humid conditions to circulate the air so you dont get blasted by warm air when you use your climate control.It circulates air across the humidity sensor. It keeps running for a while after you switch off, and starts again when you open a door. It does this so that there is less delay in getting the climate control to the right setting when you switch on (or restart).
Sep 24, 2008 | 2004 Jaguar X-Type
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Danby DKC645BLS Compact Beverage Cooler Logo
670 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
