The F28 is a communication error code.
Remove the front panel. If the flip-top cover to the right of the drain assembly is popped up, then simply pop it back down. This cover holds the wire connectors into the terminals and often pops back up when the machine agitates.
Also, here is a complete service manual for your machine. This will come in handy if you ever have problems in the future.
https://secured.whirlpool.com/Service/Sr...$FILE/8178558.pdf
Try to reset the entire board and start all over again. Anytime you fix the machine the machine needs to know that it was worked on and a reset is necessary. Good Luck
