Question about Zanussi ZBF260 Electric Single Oven
Inside glass of zanussi oven
Hi, The inside glass of my oven door came loose and has now came off altogether , how do I take the door off and refix the glass to the inside of the door.
  • lornarenwick Nov 10, 2008
    the inside glass of my oven has came loose and i have no idea how to get it back on.
  • hughdonnelly Dec 06, 2008
    Cheers DIYDIM had given up the ghost and was about to call in the expensive boys thanks for this!!!!!
    Problem Solver:
  • 11 Answers
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Posted on Dec 05, 2008
How to take the glass off the oven door to clean on zanussi zoa5525xk
usually several screws around the outer edge need removed then take the inside panel off carefully . best done on a large table
Feb 07, 2015 | Zanussi Ovens
How do I clean the oven door glass
MIX 1/2 VINEGAR &1/2 WATER PUT INTO SPRAY BOTTLE TO CLEAN. IF CLEANING INSIDE BOTH PANES OF GLASS YOU WILL NEED TO TAKE OFF THE INSIDE PANNEL TO CLEAN. USUALY THERE ARE ABOUT 4 TINY SCREWS THAT HOLD IT ON.
Feb 01, 2015 | Zanussi ZBF260 Electric Single Oven
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Inside glass fell out , how do i glue it back.
Everflex Heatmate
Temperature Resistant Glue upto 300 degrees c
Apr 24, 2009 | Zanussi ZBF360X Electric Single Oven
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Jan 01, 2009 | Zanussi ZBQ365 Electric Single Oven
Zanussi oven ZBF360 X, Door coming off
You Can buy Heat Resistant Glue at Espares.co.uk
Worked for me!
Aug 23, 2008 | Zanussi ZBF360X Electric Single Oven
Zanussi ZBF260 Electric Single Oven Logo
832 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
