Question about Whirlpool Washing Machines
Whirlpool washer LSQ9110PW3 discharges water into floor during rinse cyle.
  • Toby Norton
    Toby Norton May 11, 2010
    Have you checked the level on the unit? Since these units do spray rinses, if the unit is off level the tub will move away from the spray arm allowing it to get water on the floor. The front legs screw in and out so level the front left to right. Once these are set, pull the console towards yourself until you hear a click and set it back down. This will re-level the rear legs. (they can get off level by an off balance load).
  • 246 Answers
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Posted on Jul 23, 2008
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
During wash or rinse cyle, water leaks from the bottom
open the door,check the rubber boot for any holes,ussually that's where it leaks,also wipe the inside of the door,i've found hair and lint stuck on the inside bottom of the door and water leaks out but pull open the rubber boot and run your fingers all around it to check for any can remove the bottom panel and then run the machine to see where the leak is coming from.
Apr 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The dishwasher fills with water when it it off.
The problem is the water inlet valve has failed. This is inexpensive and easy to replace. Here is a video that will walk you thru replacing this.
Jun 03, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Draining water on kitchen floor
I am not familiar with your model dishwasher, but had a similar problem a few years back. I am assuming you have checked the obvious causes, such as a worn, or damaged gasket around the door. My problem was fixed by replacing the lower spray arm. The spray arm is a couple inches wide, about 18 inches long, has holes in it and rotates as it dispenses water - some lift up during the wsk and rinse cycles. In my case some of the holes got plugged up with gunk, which resulted in the water shooting out harder and further from the other holes. Those streams of water went places they were not designed to go and ended up on my kitchen floor. So check that part out and see if it is the cause of your problem. Good luck!
Mar 21, 2009 | Kenmore 46462 Front Load Washer
Water will not drain after wash or rinse cyles
sjjordan96,hey just had the repair guy come today. The problem is the one way valve on the washer was clogged. Its easy to get to just remove the bottom panel of the washer and disconnect the drain hose and clear the clog.
Jan 23, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Calypso Elite Top load - water discharge question
why not just discharge into the laundry tub which will allow the water to build up but get away at its own pace through tub drain
Oct 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Lint build-up on clothing after coming out of washing Machine
ck to be sure drain hose is not more than 6-8 inches into standpipe ..standpipe is 30-36 inches to top from floor ..drain hose does not fit too tight in standpipe any of the above conditions may cause water to siphon out during wash or rinse resulting in not enough water in tub to carry lint away during drain
Sep 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
