Question about HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook
Dead hard drive- does not power up, no lights or fan... What now?
We went on vacation and had our desktop turned off in case of power failure or storms- when we arrived- our monitor turns on (no pic- but lights on the side light up), the Scanner/Printer charges up, but our "Box" or hard drive is dark, no light around the start button, no fan, no nothing..
I still have internet connection to my laptop and my vOip phone line is working fine- We took the back casing off the computer drive and vaccumed it out- it was very very dusty!! and checked to make sure that all the connectors were connected and plugged in. I even tried plugging in all the componets to my OLD hard drive and the old one powered up fine.
Help! I have a 2 year old and ALL my pics and video since her birth are on this hard drive!!
I have an HP A720N
  • MalloryCat
    MalloryCat Jul 11, 2008
    This is not a LAPTOP! It wouldn't let choose the computer that I have which is a HP Pavillion A720 N.. Thanks!
    MalloryCat
    Problem Solver:
  • 7 Answers
Jikes, What ever you do Never vacume any PCB Boards or the inside of your computer. You will zap everything with Static.
A Hoover is like a Static Bomb. Rest assured you will very likely be able to get the photos back as i believe its not your hard drive that is at fault. If you need to then i can recover your photos and files.
Lets try a few things. (You might just be very lucky)
Open the Case, Turn it on its side and Remove the Graphics Card (If its not a built in on the board type) Then remove all the power from the Powerpack to the motherboard (Physically remove the Cable Plugs (Should usually be one or Two)
then remove the Power Plug on the back of the PC, wait about 5 minutes and then insert the Graphics Card, and the Power to the Motherboard, then Plug the mains to the Power Pack, Cross your fingers and pray, Switch on. If the problem still is same then remove Power from Back of PC and locate the Bios Battery (Looks like a Flat Watch battery) Check voltage if you can or replace (Should be 3 Volts or close to)
Please let us know how it goes.
Other diagnostics can be found at www.powerjackrepair.com
Posted on Jul 11, 2008
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Why did my HP desktop turn off?
Bet you a cup of coffee the power supply has gone south. Common repair. Get another power supply and install in place of old one.
Aug 20, 2015 | HP Pavilion Computers & Internet
My 22" dell lcd flatscreen monitor just went out
I know it sounds stupid, but check all the cables and connection. Also make sure the cables are in good order.
Now with that out of the way. Is it getting any lights or indications of power at all? If so it could be a cable or connection point.
Worse case senerio, if your not getting any lights or indications of power (sometimes it seems like it should turn on) the monitor may have had a capacitor or power supple unit failure.
LCD can go out like that from long use or heat. If its older than 4 years its possible its done.
You can have someone open it up and check for budging or bad capacitors. This may be a cheaper option if you have someone is town.
Sorry to hear about the monitor. Good luck!
Oct 11, 2011 | Dell Computers & Internet
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
My hp a450n won't turn on. We had a thunder storm
Was the PC running when the storm struck? In that case changing the power supply knows as SMPS which is inside the cabinet needs to be replaced provided your monitor when independently connected to a power outlet, gives a display or says 'no video signal'...................sodeep
May 15, 2009 | HP Pavilion a450n PC Desktop
Computer won't turn on at all
I think ur power supply SMPS inside the systemneeds to be replaced...
Jan 03, 2009 | Gateway GX7018E PC Desktop
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
My monitor does not turn on
there is power problem  in your monitor.check the fuse,regulator,and horizontal output transistor
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Monitor Failure
Your system was not affected because the PSU can prevent power surges. Your monitor's backlight has went out due to surges in electricity to your monitor. Unfortunately, you can not replace the backlight. I would suggest you buy a new monitor. 19" LCD Monitors has have went down dramatically in the past month.
Aug 25, 2007 | X2Gen MG19MY 19" LCD Monitor
HP Pavillion ZV6000 Athlon 64 3500+ 15.4in WideScreen w/ 512MB/80GB/DVDRW/Flash Slot (PCLHCA6435512WWD) PC Notebook Logo
592 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
