Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Filter light won't go off
We changed the filter and ran water thru the door but the "change filter" light won't go off. We unplugged the refrigerator for awhile and the light is still on. any suggestions?
  • Anonymous Sep 18, 2008
    my fridge is a Maytag and the filter light will not go off, there is no button to press at the filter light, any suggestions, I have changed the filter
  • 254 Answers
Did you press and hold the reset filter light for at least 3 seconds?
Posted on Jul 30, 2008
After changing the filter, you must reset the Filter Change Indicator Light by simultaneously pressing and holding the "light" and "lock" buttons until the filter lamp begins blinking. Release pads and the lamp turns off. Indicator is now reset.
Posted on Sep 18, 2008
Water dispenser does not work
Good Afternoon Friend,
I understand that the water dispenser on your Frigidaire refrigerator does not work. First, I suggest changing your water filter, making sure that the filter is flush with the filter housing. Secondly, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try to get water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is required, please leave me the model number of your refrigerator. Typically you can find this number inside the refrigerator on the right hand wall. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Samsung refrigerator filter light won't go off after new filter installed
Press and hold "Alarm" touch pad for 3 seconds and it should reset the filter light to blue.
Feb 02, 2013 | Samsung RF4287HARS French Door...
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
No water from the door.
Below the freezer door, behind the toe kick is a water line union disconnect it and hold the incoming line into a cup, have someone press the water button to see if the water is getting up to that point. If it is, then the water line is frozen inside the freezer door, and you will want to get a heater kit for the dispenser (small heater that attaches just below the water spout in the dispenser).
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Water tastes funny
if there filter was not properly installed you would not have any water at the door.
you do not need to turn the water supply off to change the filter.
you should be able to push the filter light for three seconds,they do not turn off they just change color
May 28, 2010 | Samsung RF265AA Bottom Freezer French Door...
Water filter change, water runs, indicator light still on.
Hold in the lock button AND the light button in for about 5-10 seconds .
May 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Since changing filter have no water in door and no ice
usually there is a reset button on the fridge that needs to be pushed.you may also try and unplug the unit for a few minutes
May 19, 2010 | LG LSC26905TT Side by Side Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
465 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
