Question about SanDisk Sansa e250 MP3 Player
Refresh database Holding the power buton down to reset the player does not work.
    Problem Solver:
  • 6 Answers
Thats not haw you reset the player. if it says refresh database thats because you put in a micro sd. just take the battery out. unscrew the for screws on the back you arent taking it apart completely your only taking the cover for your battery. just like your cell phone
Posted on Jul 13, 2008
Frozen sansa at refresh database
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
IT's froze again, Arrrrrrrrrgh!
Try resetting it: To reset sansa: holding menu for 15-20 seconds. or Or-To reset the sansa = Hold down power button for 20 seconds.
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database error
Used the Firmware Updater to get the latest firmware and this updated my Sansa E260 player which was in Recovery mode. The player then completed the refresh database process. No data was lost. The player is now functiining correctly.]
Thanks
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Refresh Database
Firmware upgrade needed most likely:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 06, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database
-Tha Mp3 Doctor
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Frozen screen says: refresh database
tyr taking the battery out or try holding the power button and the play button at the sametime for 20 secs.
Oct 21, 2007 | SanDisk Sansa e260 MP3 Player
Refresh database fail
ALL DATA WILL BE LOST WITH THIS PROCEDURE!! You can try a ROM recovery. - TURN OFF UNIT - Place hold switch so orange shows - Hold down the REC button with the red dot on the side of the player. - Whilst holding the REC button, press the power button as if to turn on the unit - Let go of the REC button You should see the recovery console. YOU WILL LOSE ALL DATA!! However you will also have a working player. Hope this helps.
Aug 21, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
