Question about Coby MP-C844 (256 MB) MP3 Player
Button is stuck
One day I noticed that the 'arrow' button gets stuck. When I press it, it wouldn't come back up. Maybe I have pressed it too hard. But every time i tried to switch to a new song, it either changes it or goes into fast forward. If I shake the mp3 player or try to move it, it would change songs for itself. What can i do to get the button to unstick?
SOURCE: Creating Playlists
You need to do the following steps: 1. While the song is playing, press and hold the joystick button. A screen will pop up. 2. Select 'Favorite (+)'. Once you do this, you should be able to see the song in your 'Favorites' folder.
Posted on Jul 19, 2007
SOURCE: My player keeps repeating the same song
maybe you had press the repeat button
Posted on Jul 20, 2007
Crazy L8tz
SOURCE: How do i keep,my songs on my mp3 player,without overwriting them?????
in order to help you illl need more information, like what programs are you using to download and convert them into your mp3 player? i use rhapsody, because when i used to use windows media player it would give me the same problems you seem to be having. P.s. my e250 screen is broken v.t it was the only thing holding my entire colection of kick ass songs, most of which are irreplaceable due to undownloadableness. i could kill myself
Posted on Aug 05, 2007
  • 6 Answers
SOURCE: mp3 player plays in fast forward
Maybe the player that you are using is loading them this way. Check your playback options and see what speed that they are on.
Posted on Dec 18, 2007
SOURCE: Living Solutions MP3 Player
I have one but i have no clue how to work it lke how to download songs!!
Posted on Jun 14, 2008
Hard reset for a fuji finepix jz500
1.Press the "Menu/OK" button on the back of the camera.
2.Highlight "Set" on the LCD display by tapping the "Right" arrow button.
3.Select "Set-Up" using the "Down" arrow button. Press "Menu/OK."
4.Select option "5" by tapping the "Right" arrow button. Press the "Down" arrow button.
5.Select "Reset" by tapping the "Down" button. Press the "Right" arrow button. A confirmation message appears.
6.Press "Menu/OK." The camera resets itself to factory defaults
Sep 25, 2011 | Fuji FinePix A700 Digital Camera
I connect the charger of my htc hero. at first it was charging. after an hour i noticed that it stopped from charging. when i turned on my phone it didn,t open.
Open the back cover , take the battery out . Press and hold the power button without the battery . Put the battery back in . Try to power it on .
If that doesnt work try below steps , ( note : you will loose your data )
Power the device OFF. Press and hold the HOME and Back Arrow buttons. While holding these buttons, press the End Call button once. Release the Home and Back Arrow buttons and press the Trackball to execute the Hard Reset. The device will reboot once the process is complete.
Thumps for my solution if it works .
Aug 15, 2011 | HTC Hero Smartphone
How do I put the correct date and time on my new cezais998 series
From the base unit,
Press MENU
Press down arrow button on right side of base down two times.
Menu item DAY and TIME should show up.
Press Menu.
Adjust day by pressing up or down arrow,
Press Menu.
Notice how the indicator moves to the next step, time.
adjust time using the up and down arrow,
move to AM/PM
adjust using up down arrows
press Menu to lock new time and date into the unit
good luck!
Jun 09, 2011 | Uniden Cell Phones
Hello, I have model 49556/te158wt and I'm not able to set hour ! could you help me ?
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Link above is the Woods 49555 manual
If the timer will not program, then it has gone bad.
Plug timer into wall receptacle
Back-up battery will charge in about 1-2 hours > if battery will not charge, then timer is no good
Some digital timers require back-up battery to be fully charged before display will show
Back up battery allows programming while timer is removed from receptacle
After timer is programmed, plug timer back into receptacle
Timer buttons show below
To set current time:
Depress RST (Reset) button to clear programs
Press-and-hold TIME button to select 12 hour or 24 hour display
Press-and-hold SET button. Mo Monday will flash in display
Push arrow button until current day shows
Press SET button again. Hours will flash
Press arrow buttons until current hour shows (am or pm)
Push SET button again. Minutes will flash.
Press arrow buttons until current minutes show
Programming ON-OFF
Make a schedule so programs don't conflict
You can set up to 20 on-off programs over 7 days
Each program has ON time Day Hours and Minutes
Each program has OFF time Days Hours and Minutes
Press right-arrow > PROG 1 ON flashes
Press SET > choice of day groupings flash
Press arrow button to select days
Press SET > program1 ON times flash
Press arrows to set ON time
Press SET > program1 for Hour
Repeat sequence described above to set MIN
Repeat sequence to set OFF times for program1
Repeat sequence to set Program2 thru Program20
Press TIME button to finish programming
Oct 12, 2010 | Woods 7 Day Digital Heavy Duty Timer...
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
How to set the time on my GE 27958GE1 Cordless Phone
1) press FLASH/PROGRAM until SET DAY shows
2) use MESSAGES/CID or the arrow buttons to select current day
3) press FLASH/PROGRAM until set time shows
4) use touch-tone pad to enter 1st, 2nd, 3rd, & 4th digits
5) use MESSAGES/CID or the arrow buttons to scroll to AM or PM
6) press FLASH/PROGRAM again to store your selection
7) press FLASH/PROGRAMrepeated to exit
I copied this from my manual onto a sticky label & have it stuck on the bottom of my phone for future reference.
May 21, 2010 | GE 27958GE1 Cordless Phone
How to disable the resolution notice on VG930m
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
My dell printer 926 is not in englishand i cant read the display to try to change it. please help
To select the language on the Dell Photo All-In-One 926 printer, follow these steps:
  • Completely power down the printer, wait 15 seconds, then power it back on.
  • Press the Right Arrow button three times.
  • Press the Select Button.
  • Press the Right Arrow button four times.
  • Press the Select button.
  • Use the Left/Right Arrows to display the language you prefer.
  • Press the Back button to get back to the main menu.
have a great day :)
Sep 28, 2009 | Dell 922 All-In-One InkJet Printer
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
Have a daenyx dv-833 dvd player
Good Morning,
Your connection is very easy so we should not have a problem isolating the problem.
We just have to go slow step by step.
First lets just check the Yellow cable just to be on the safe to side sure it is connected properly on the back of the DVD player and on the Televison.
Second, If the connectionn is secured. Turn the DVD player on, make sure you do not have a disc in the tray then turn the DVD player off.
Make sure the battery on the remote control is a fresh new battery (process of eliminattion).
Hold the remote control in front of the DVD front panel.
Turn the DVD player on with the remote control. Look on the front panel of the DVD player, it should read no disc. Press the Pro.Scan button "once". (Have you notice a flickering on the Television Screen).
If no flickering on the TV screen, press the Pro.Scan button again, ( this will be the second time). Have you notice the flickering?
If not, press the Pro.Scan button again ( third time). Have you notice a flickering on the TV screen?
Did you not notice on the LED of the DVD player if it read anything when you pressed the Pro.Scan button?
Try the above procedure again if your picture did not resume. If the picture resume in black and white, do not press the Pro.Scan button anymore.
Let me know the outcome up to this point.
Thanks,
Mike H.
Nov 02, 2008 | Televison & Video
Coby MP-C844 (256 MB) MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
