Question about Durabrand Anti-Skip CD-895 Personal CD Player
Stop playing My Durabrand was a year old in May 2008 and it stop playing my cd's months before I hit that date, unfortunately, I don't use it everyday so I can't be sure of when it stopped playing. What can I do?
  • 79 Answers
Try cleaning the inside of it. Dust and what not can wreak havoc on electronics. That's cool, I used "what not and wreak havoc" in the same sentence. Hope this helps.
Posted on Jul 19, 2008
How do i change the time on T5K801 Marathon watch
To set time and date:
1) With time and date showing,
press SET and hold for 2 seconds.
2) Seconds flash. Press START/STOP to set seconds
to zero.
3) Press MODE
Hour flashes.
Press START/STOP
to change hour, including AM (no symbol) and PM.
4) Press MODE
Minutes flash.
Press START/STOP to change
minutes; hold button to scan values.
5) Press MODE. Year flashes.
Press START/STOP to change year.
6) Press MODE
Month flashes.
Press START/STOP
to change month.
7) Press MODE
Date flashes.
Press START/STOP
to change date.
8) Press SET
, at any step, to exit and save settings.
With time and date showing, press SET
to switch between 12- or 24- hour time format.
Date (day of month) appears in upper part of display in Time
mode. Press and hold START/STOP
to see month, date, and year in large digits
Or go to:
http://assets.timex.com/user_guides/Marathon/W292-Marathon-AllLanguages.pdf
Jul 31, 2017 | The Watches
Cd-s start-and-stop play intermittently
Hi, you have one of 2 possible problems, either the laser is dirty and needs cleaning, this can be done by going into any computer hardware store and buy a lens cleaning cd, its like a cd with brushes on it that you put in and when it spins round it removes any dust,
or the other problem is going to be that the laser is coming to the end of its life, now as its 8 years old then chances are the problem is with the laser or the motor that spins the cd, these only have a certain life span and dont last for ever, so if cleaning dont work then this means the laser unit needs replacing, so you would have to work out repair costs, and thats even if the parts can be bought and replaced as its 8 years old so you might struggle to get it repaired
May 18, 2012 | Pioneer Premier Cdx-p686 - Cd Changer -...
How can I get the cd changer to stop changing non stop?
Something is out of timing. When powered up, the unit trys to get to a known state and will continue until it reaches that state. If the timing of the gears has been changed, this may not occur.
I'll try to see if I can create a set of instructions to re-time this.
Dan
Mar 11, 2009 | Sony MHC-GX450 CD Shelf System
Mitsubishi HS-U500
Just set it to record"today" choose the correct day and month,the year will be unimportant.
Sep 24, 2008 | Mitsubishi HS-1280U VHS VCR
Picture Tube
Hi. Thanks for writing this posting. Saturday, my 19" Durabrand tv literally stopped working. Before it shut down, I had a partial screen and when I turned the tv off (hoping that the problem would somehow rectify itself), it wouldn't turn back on. I had it for only *four* months. Comcast gave me an 800 number but it rang to a fax signal. When I saw the posting here, I clicked on the Lenoxx site and called their 800 number which did not even ring. I called information and received a number, 877-874-8394 for Lenoxx Manufacturing but the person who answered said that they are Plaza Wire Design with Lenoxx being one division - but they manufacture towel racks. Ugh!
Unfortunately, this all happened one month after the 90 day return policy at Walmart *and* they don't even carry the product anymore. (I don't know whether it is because of defects or turning over to LCD.) One year prior to this, I purchased a cd/radio which also stopped working (the cd player). Luckily, it *was* within the 90 days of purchase and I returned it. They stopped selling that product as well.
What recourse do people in our situation have?
Jul 23, 2008 | Durabrand DWT2405 24" TV
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
Cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
Dec 23, 2007 | Durabrand W600 Shelf System
Setting the Clock
1.In the stop mode, press and hold down the MENU/STOP button for at least 2 seconds
The menu setting display appears.
2. Press the SKIP/SEARCH button repeatedly to select dAtE
3. Press the POWER/PLAY button.
The year display blinks
4. Press the SKIP/SEARCH button repeatedly to select the year. Then press the POWER/PLAY button. The month display blinks.
5. Repeat the same step 4 to set the month, day, hour display ("24 H or "12H") hour and minute. Note: "second" cannot be selected.
When the minute setting is completed, "dAtE" returns.
6. Press the MENU/STOP button.
Nov 01, 2007 | Sanyo ICR-B60 Digital Voice Recorder
88 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Jonathon summesfield
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
