Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
Ram for intel d845glva board
Can i put hynix 512 ddr 400mhz ram in intel d845glva motherboard. will it support it
  • 983 Answers
System Memory Features
The D845GLVA board provide the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • Maximum total system memory: 1 gb or 2 GB ; minimum total system memory: 64 MB
  • DDR266/200 MHz SDRAM DIMMs only
  • Serial Presence Detect (SPD)
you can visit the intel site if you have any doubts here is the website below you can see the d845glva product information
http://support.intel.com/support/motherboards/desktop/d845glva/sb/CS-012941.htm
but your motherboard supports only 266 and 200 mhz RAMS
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my soution
Posted on Jul 11, 2008
My Question to you is, Can I use my Nanya NT256D64S88AAG-7K in my Intel Board D845GLVA ? I read the ram must be " D series ram " to run this board, That is why I am asking. As I have tryed to run them...
Yes, this is a DDR memory that should work in your board. Put it in and start the pc : one, two or three beeps at boot indicate defective memory. If you don't hear anything then the board itself is dead.
Oct 17, 2010 | Intel D845GLVA (KD845GLVALPAK10)...
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
Ram upgradetion
Yes U can use maximum 2GB RAM in ur motherboard...
Dec 03, 2008 | Intel D845GVSR Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Upgrading RAM
Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
  • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
  • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
Note:
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
Enjoy the increase in RAM,
Lee
Jun 14, 2008 | Intel Desktop Board D845GLVA...
System memory FSB
Have you tried installin the memory in various slow...ie 1,2/1,2/1,4 etc?
Its sounds like your mother board is unable to run the sticks at the rated speed as they are different brands and densities so its dropping the speed to 166.
Have you tried going into the bios and changing the ram speed there?
Also try changing the command rate from 1T to 2T to see if that helps.
Dec 29, 2007 | Computers & Internet
D865 Perl with 80 gb sata plus 1024X2 400Mhz DDR Ram
-check your reset button if its not stucked. -else try resetting your CMOS settings to default. -try using your old memory sticks.
Sep 13, 2007 | Intel D865PERL Motherboard
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
217 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
