Question about Ricoh Aficio CL7000 Laser Printer
Network printer installation problem
I am facing problem in vista machine
1) installaing printer in vista machine facing some problem x0000006 error
2) printer have sucessfully install in vista machine but test page not coming in printer (print is not come in spool )
  • bhandariprit Jul 11, 2008
    pls my problem solution as soon as possible
    thanks
    prit
Are you using the proper Windows Vista Driver? You can't use the XP version...here's a link to the download page:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/cl7000/cl7000en.htm
Posted on Feb 14, 2009
Printer is not working properly
Because of your printers' corrupt software or hardware, you might face installation errors. To reslove this issue, you need to reinstall the drivers and software. Make sure that you get only the most compatible driver for installation. Source(s): http://printers.iyogi.net/canon/installa...
Nov 06, 2010 | Canon PIXMA iP1300 Printer
How czn i install my printer so that can network
You first need to check if the printer is compatible with Vista. Then, if it is,Install the printer on one of the machines. Once it has installed, go into printers and right click on the printer itself, then select Sharing or Sharing and Security and allow the printer to be shared. You may have to switch on file and printer sharing before you can share the printer. Then, go onto the other machine and go to install printer. In the dialog window that opens, choose network printer and then search. When the printer appears in the search area, select it and choose install. The system will then download the appropriate drivers from one machine onto the other through the network and install the printer. This assumes that you have both machines connected to your home network and file and printer sharing is turned on, on both machines. To use the printer over the network, the machine the printer is connected too MUST be turned on.
Dec 12, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Error Message on Printer
your printer driver is not vista supported or motherboard driver is not properly instaled
May 29, 2009 | Lexmark X5270 All-In-One InkJet Printer
Can't print from Vista Laptop
You need to go to printers and faxes.  Set up a new networked printer.  Take the drivers off of your vista machine, because by using those drivers, vista is thinking that the printer is physically hooked up tot hat computer.
Feb 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cannot print over the network
dear sir..
for vista u ned to install "netbui" componant to network device and when u install it's u need to connect mac pc to vista thru network then it's connected it's worked... it's help u..:0
dear sir,
there is no need to install any drvier install in to windows xp if yr pronter allreadt install in pc then right click on printer then got to shring then select share as then give a name... after this prossess go to windows vista and open yr pc thru yr network placess it's show printer which connected to windows xp just dabble click then it's show u "Are u sure to install network printer" somthing like that... just click yes or ok... it's help you..:)
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
thanks
plese vote
jo_chinmay
Nov 23, 2008 | HP PSC 1350v All-In-One InkJet Printer
HOOKING UP A PRINTER TO NETWORK USING PRINT SERVER
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
Jul 25, 2008 | IOGear GPSU21 Print Server
Error: installation ended prematurely because of an error
That is the problem with VISTA...Those softwares which were workin in XP is not supported by vista...(different platform)...or else go for the software developer and get the vista version
PLEASE VOTE ME AS FIXYA (blue boxes) for my help.........
May 27, 2008 | Computers & Internet
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
Apr 08, 2008 | Alps MD 1000 Thermal Printer
Hp 1280 injet
The vista network setup not properly set.
Feb 21, 2008 | HP DeskJet 1280 InkJet Printer
Ricoh Aficio CL7000 Laser Printer Logo
445 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
