Question about Durabrand STS92 System
No sound from my home theater system when switching it on
There is no sound coming from my home theater system when I power it up. All of the speakers are connected properly. The fuses is good. There are no wires touching. It is connected to PC. But I still cannot get sound from it, even if I connect it to any other device. Is it time for a replacement, or must I go into the subwoofer. All the cables I need are connected. I tried all that I could try. Ifs there anything else I can do before I ditch the system?
    Champion:
  • 224 Answers
On the front of amp,there usually is 2 buttons for speakers A & B,make sure both are depressed
Posted on Jul 15, 2008
Have a Philips 5000 series home theater system and just hooked it up and can not get any sound from the left side speakers front and rear. What should I do or I did not do Thanks.
Most of these home theatre systems come with a speaker set up. Try that. Also look at the speaker settings. It's possible that the speakers you mentioned are switched off, or their output is set to low.
Nov 25, 2016 | Philips Audio Players & Recorders
I have polk audio rm 705 purchased from my friend a month ago. these are working fine but one day one speaker just have very low sound coming from tweeter where as the main speaker is silent.
Try switching the speakers left to right. If the same speaker is bad on both channels, the speaker is bad. If the good speaker is now bad, the unit driving the speakers is bad.
May 23, 2015 | Polk Audio Rm705 5.1 Channel Home Theater...
Works for 5 seconds
This sounds like a power problem .. It may have a switch mode power supply... turn it on and listen if you can hear a faint clicking sound ... maybe the switchmode power supply is not switching on properly.
Feb 28, 2014 | Vizio Vht210 2.1 Home Theater Soundbar...
System is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
Jul 16, 2009 | Samsung HT-AS720ST Theater System
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Rear spekers no sound
Is the source signal of a surround sound type? Also, be sure that the rear speakers are on, (if your receiver has a speaker switch on it), and they are hooked up properly.
Mar 23, 2009 | Sony HOME THEATER SYSTEM System
No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 07, 2009 | Denon AVR-4800 Receiver
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
Durabrand STS92 System Logo
43 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
