Question about Sony Televison & Video
Unable to view digitial tv pictures but audio and analogue pictures work
My TV was working perfectly this morning, but when I turned it back on tonight the digital picture on all channels is blank, but I can still hear the audio? Analogue pictures & audio still work ok....just the digital pictures dont work.
  • troy432 Jul 11, 2008
    I just found the solution..... the on/off switch! I turned the TV off at the wall, then back on again & the digitial picture is back! TVs & computers are becoming more & more alike. Doh.
    Sergeant:
  • 280 Answers
If you have cable and a top of set box , it may be the problem. If you hook the cable direct to the set and still no digital ... then the TV could have a defective digital board. The tuner is on this board and the tuner gets both analog and digital signals.
Posted on Jul 11, 2008
  • coyotedave Jul 11, 2008
    Ah yes the old reset. I forgot about that one. the micro IC don't lock up that much good for you to think to turn power off /then on.
    That resets the IC and puts it in the default mode.
No sound
Make sure your not using spanish audio programming make sure its not muted depending on the tv some tvs have speaker off and the audio would pass through the rca out.. If your using equipment to view tv make sure your audio in is plugged in.. Change channels and see if you have audio than
Mar 25, 2014 | LG 47LC7DF 47 in. LCD HDTV
I have my Sony flatscreen (KDL-40XBR) attached to a Panasonic DVD recorder. I recently lost all digital channels on my TV and no digitial channels can be found when I do a full scan. I can still get...
From the looks of it the tuner seems to be malfunctioning. You are able to get picture through your DVD recorder because the signal is directly fed to the audio/video proecessing circuits , when you connect via the HDMI, Component or RCA ports at the back of the tv. Since this mode of connection also ensures better quality signal I suggest that you continue using it as this problem can only be resolved by replacing the main A/V board on which the tuner is located. The board costs about 100-125$ and is not very hard to replace. So if you wish to replace it, then let me know and I will give you the detailed instructions along with the link to the part.
P.S: Bad Rating = No further help.
Aug 15, 2011 | Sony Televison & Video
Trying to hook my lg tv to a denon avr-1707 receiver so i can have external speakers
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Jan 31, 2011 | Denon AVR-1707 Receiver
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
I turned my tv on and the picture was green and purple. Had to adjust all of the colours to get a somewhat normal picture but it still isn't what it should be.
Turns out it was a problem with my HD satelite feed. Blueray worked perfectly. Turned tv on this morning everything back to normal.
Jan 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
LG 4912 using with a new digital TV
in order to solve the complect of channel/ choose one / if tv is digital in line w/dvd is digital.
If your your recorder is analogue choose use analogue channel.
Dec 14, 2007 | LG DR-4912 DVD Recorder
Televison & Video Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
