My oven is beeping and F0 keeps flashing. When I try to touch the panel, nothing happens. This just began an hour ago...The F0 will leave the panel, but then I my oven will not work.
-   Does anyone know how much having a new key pad and control panel replaced would cost?
-   kariesmail
Jan 03, 2009
-   I have the same problem.
-   binyang2005
Sep 13, 2008
-   We have the dual oven. The F0 code comes on both sides of the display, indicating it's in effect for both ovens. Only the cancel key seems to work. If we turn power off for a minute (min 30 seconds), we sometimes get the oven to reset for a few minutes up to a few days.
The tech manual says the problem is either: the control unit or the keypad (i.e. replace them). Another group says the problem is the keypad or corroded connection (ribbon connection) and to use rubbing alcohol on the connector. Unfortunately, the connection did not improve after cleaning, so I'm about to purchase a keypad. After that, a control unit.... Any help out there as I would think the solution would be simpler...-   almink
Sep 09, 2008
-   Our oven gave the same F0 error message. And all the keys did not work. After we turned off the power and turned on power again, we hold bake and brill keys for 3 second, it changed to flash mode. But all the keys still not work. We used the oven a few weeks ago, it worked well and we did not do any thing afterwards.-   qunq
Aug 25, 2008
-   how can the error FO be fixed and the beeping to stop-   Guest
I run Ubuntu 8.04. I installed drivers through Easycam2 yesterday. Camorama worked, but the image...
(More)
I run Ubuntu 8.04. I installed drivers through Easycam2 yesterday. Camorama worked, but the image with Skype was very bad. Today, nothing works. Camorama is blocked, and Skype starts without video option. The ID of my webcam is 046d:08f6
i have a cif usb 2110 webcamera and i need the driver for it to work.is there anything for free to...
(More)
i have a cif usb 2110 webcamera and i need the driver for it to work.is there anything for free to get my camera to work ,thanks
