Question about Kitchen Ranges
Attic roof vent fan- brand unknown. need motor and blade
Put a new motor 3.4 amp 1050 rpm into a roof vent fan 6 years ago. Two years later, customer complained of noise so got new motor under warranty. Now, complained again. (I do not hear noise). Suspect bent blade. Unit has no marking on it. Thought it was Butler Ventamatic and was going to buy entire unit for $60 and swap motor and blade, until I discover blade is only 12". Butler Ventamatic does not make a 12" blade. No name on tstat or dome. Has metal flashing and dome, 3 stud mount. Can I take a chance and get 12" "universal" attic blade and should I use another 3.4 amp motor or get 4.3 amp? Thanks.
  • 195 Answers
Any Blade will be ok if it will fit shaft and they all should be cosistant and of course the higher the amp the better quality.I like the Pro 3 model at Home depot but I believe the Pro 1 gable is the 12 inch blade,pro 3 is 17 inch houseing and maybe 12 inch also.
Please rate jj505 Guru
Posted on Apr 06, 2009
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
My Panasonic FV-11VQL2 seems to have the damper stuck in the closed position. The fan does not exhaust well, ever since we got a new roof (vent and 4" duct too). Any way to unstuck it without going into...
Hubby went into attic. The roofer did a poor job installing the new 4" duct and roof vent; duct was poorly attached and pinched at both ends. He redid both connections, and now the fan works well----no more foggy, drippy mirrors!
So, the fan is fine------the installation of the new roof vent and duct was shoddy.
Aug 24, 2009 | Panasonic Dryers
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
2 fans have burnt out in less than 1 year
I would say the motor is pulling to much amp draw.When you install it watch you place the fan blades in the air steam.May be you are moving to much air and that will make the amps go up and cause the motor to over heat.Also hope you are getting the same hp and rpm.
Apr 05, 2009 | Heating & Cooling
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Kitchen Ranges Logo
712 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
