Question about Alesis MasterLink ML-9600
CD RESET FAILURE
When I switch on my Masterlink the screen reads FATAL ERROR,CD ERROR 277.Then it goes to the main masterlink page and reads HDCD CD reset,CD Reset Failure.If I press the HD/CD button to reset the screen readsSYSTEM ERROR,CDR Reset Failure,I've tried all the reset actions,like holding plat and record while starting up but this does nothing.And I cant get the cd tray to open.Please help.
  • gatchaspalta Oct 09, 2008
    I have the same exact problem.  I cannot reset it for some strange reason.  I haven't used it for awhile, and this happens.  Does the Masterlink's HD and CD drive goes bad when not used for an extended amount of time?
  • Anonymous Nov 04, 2008
    I have the same problem with one of the Masterlinks in my studio. It is used almost everyday, so I do not think that the error has anything to do with non-use. I checked all cables and all are in the right place and secure. Any guesses?
I have the same problem. I have traced it to a bad CD Player/Burner. A replacement along with a new eprom chip in order to run the new updated burner can be ordered directly from Alesis- number on their website for $70 including shipping. I was able to troubleshoot it by dropping a new Panasonic DVD/CDR burner in the unit. It powered right up but wouldn't recognize the CDR. The unit will function without the proper CDR however- just no burning. This is an easy fix if you are at all technical.
Mike C.
Dubway Studios, NYC
Posted on Nov 04, 2008
The CD ERROR 277..can be fixed if u make sure the internal cable connection between the Hard disk and the writer are not mixed up and are well fitted...
Posted on Oct 11, 2008
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
HDCD Reset CD Eject Failure
Replace the CD drive. There's a list of compatible drives online. There's instruction online for replacing CD drives in PCs, the Alesis is no different.
Sep 26, 2013 | Alesis MasterLink ML-9600
My masterlink wont validate OS; it all started with HDCD reset apearing. I formatted HD, no change so tried latest OS, no change!,,,,, I put in a new hard drive and 2.18 OS still no go . What else can i...
hd would have been my guess.
There's not much in side the unit. If you could send it to me, I could look at it. send both HDs too. I could trouble shoot and let you know.
contact me.
bcssr@charter.net.
thanks
dave
Apr 20, 2011 | Alesis MasterLink ML-9600
The CD drive won't eject
i have had this problem with "system error" and "hdcd to reset" on the screen. try powering down, then unplugging from ac for 30 minutes. power up while pressing hd/cd button.
good luck.
charliewrrmc@gmail.com
Aug 23, 2010 | Alesis MasterLink ML-9600
Upon turning on our Masterlink, it read "LOAD OS".
if you are computer savy, you can disassemble the masterlink and test the cd drive in another computer. if it works, check the power connector to the cd drive. switch it with the hd connector to see if it fires up.
keep use posted.
bcssr@charter.net
dave
Apr 14, 2009 | Alesis MasterLink ML-9600
Corrupted playlist... hdcd to reset... tried that.. doesnt work
I had the same problem.....but reading your post helped me with my corrupted file. I just powered up like you said and immediately held the create cd button and utility button. I held it until the formatting was finished. problem solved....but lost some music in the process. Charlie Woo.
Feb 04, 2009 | Alesis MasterLink ML-9600
Alesis Masterlink ML 9600 won't power up.
After reviewing the repair and owners manuals. I have come to the conclusion that there is a short in the power supply board. Your drives should be fine. I don't know off hand how expensive it is to fix in your area. I would say approx $200
Jan 19, 2009 | Alesis MasterLink ML-9600
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
Masterlink
I tried the "pressing play/pause and record simultaneously" during power
up, and it worked.....dunno for how long. The unit still makes strange
noises occasionally and doesn't seem completely healthy, but it's up
and I'm copying files that I want to save. We'll see.
Jun 12, 2008 | Alesis MasterLink ML-9600
System error
you may need to change the hard drive.
try ebay for a 30 or 40 gig.
dave
May 27, 2008 | Alesis MasterLink ML-9600
Alesis MasterLink ML-9600 Logo
975 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
