Ferguson FRG-R121D digital radio doesn't work. Only works on fm stations and then very poorly. Takes a long time to switch on with continuous clicking noise.
  • yaz123 Jan 12, 2009
    Same problem -- twice
I had the same problem and solved it. Mine took about 10mins to turn on (constant buzzing and beating before this).
The problem is the 1000uf and the 220uf capacitors on one of the circuit boards near the front of the device. I replaced these with new ones and problem sorted.
So if you know what your doing, take it apart and solder in some new caps. If not...maybe get a new one!
David
Posted on Dec 22, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
This is before I read this post and answer above...
I had the same problem with my Ferguson DAB FRG R121D which was just over 2 years old...
First of all it had the display flashing on and off, with popping noise on speaker, then went off completely with faint buzzing noise remaining on speaker.
I noticed inside on the board just behind the front panel...the one with the copper screened section on it, taht the 1000uf 10V cap had domed (ie instead of flat top had domed top = usually means it is ccoked)...I replaced it with a 1000uf 16V one - can is bigger but fits OK - Maplins part number VH50E (£0.56p!)....did the job. Is now fixed but I still have the buzzing noise - so I'll get it open again and change the 220uf as suggested above....
By the way you need a smallish Philips fairly long reach screwdriver to get some of the back screws out.
Posted on May 29, 2010
  • Rental John May 31, 2010
    220uF didn't help with the mains hum....any ideas anyone?
  • Rental John May 03, 2015
    5 years later! I've finally repaired my radio...it was the 3300uF and 2200uF capacitors on the power supply board...I now have crisp clear and basey audio and no mains hum/buzz. I found this site which gave me the top tip www.richsradios.co.uk/fergusondab.html
I found the 2 domed caps at the back in the PSU area. I also still have the mains hum, really need a pointer on this.
Posted on Oct 28, 2011
  • Rental John May 02, 2015
    In addition to my much earlier comment...I still have the annoying background buzz / hum though dab rsdio works ok... any ideas?
AM stations not working, FM ok, replaced radio and still have the same problem
check the area that you are in as many stations no longer broadcast am. Radios now are fm or digital.
Nov 12, 2013 | 2007 Cadillac DTS Sedan
My radio only works for a short distance then goes staticky, also can't set the time
the operator guide in the glove box , covers time set.
all radios do that.
and if not normal, the antenna is broken or fell off the rear of radio.
if got static switch to FM ,
many AM stations, broadcase to am and fm same content.
so use FM. its static free. (by design) but does fade sooner.
you can in fact hear AM station 12,000 miles away it night
called super stations, 50,000 watt stations. ive done this many time.
did you try another car, in same spot , and same station?
are you in under ground parking?
Aug 13, 2013 | Jeep Liberty Cars & Trucks
FERGUSON FRG 810 D DIGITAL RADIO
The request is not specific of the fault.
Nov 22, 2011 | Audio Players & Recorders
Our Ferguson FRG-CR100D DAB Alarm Clock Radio has lost its digital display - it just shows 16 illuminated blank oblongs in the display panel. It doesn't respond to pressing any buttons, e.g. DAB/Clock,...
Hello
I experienced a similar problem some time ago. I thought I was responsible for the problem because I run the radio of a dual voltage shaver socket and accidentally switched the socket output to 110v. From that point on the radio did excactly what you described. I perservered in trying to find out why but to no avail so I abandoned it. Some months later out of curiosity I plugged it, switched it on and it worked perfectly.
Try leaving it unplugged for a few days (which by this time will have already passed). It may just recover like mine did.
Nov 16, 2010 | Audio Players & Recorders
My ICF-SW77 quit picking up on AM as well as FM. Then all of a sudden every thing works well for some time. Worked well all night, but this morning a tried to tune a new station and now again no pick up on...
Possible poor contacts in radio, as they age this happens. Could be one or more bad capacitors, same age problem. I do repairs on these radios, email me on this .... Rod ( poikaa@yahoo.com )
Apr 30, 2010 | Sony ICF-SW77 AM/FM/SW Radio
My problem is how operate radio in this system give me details of this radio station
Radio will not work, unless until you plug in the headset.
Go to Settings, Reset FM, confirm with Yes.
Then go to Radio, it will automatically set the radio stations to ch01, ch02, ch03,...ch20.
That is Twenty radio channels will be set.
You can press the record button only once, to display the station names, if you press record button continuously it will start recording the program which is broadcasted in the selected radio station.
Cheers...!
Mr.Maduraikaran.
Jan 20, 2010 | Transcend T-Sonic 840 MP3 Player
Audio output from digital radio failing
No solution I'm afraid! I have exactly the same problem! Did you work out how to fix it or what? This happened to our radio yesterday and I've pushed every button I can to try and sort it. I know the speaker works and is connected because I can hear a faint buzzing sound when the radio is switched on.
Jan 10, 2010 | Audio Players & Recorders
I have a 6 CD Changer but dont know how to use it?
This is an older way that makers of CD changers used to get CDs into cars that didn't have them.  This is what they tried to get people to by them.  I was never a fan of this system as the sound quality was never better than listening to FM radio.  There is a unit in the car, usually under the dash behind the glove box, that the CD changer is plugged into.  This unit has the FM antenna from the car plugged into it, and then a cable that is the same as that coming from the antenna going from the unit under the dash plugged into the FM antenna jack of the radio in the dash.  All this unit does is take the digital, high quality sound from the CDs, transmit it on an FM frequency (usually low on the FM band 80s, 90s or low 100s) and then you tune the radio into that FM frequency to get the sound form the CDs.  Problem is, the sound quality was only as good as FM radio.  A pretty poor way of getting CDs into cars.  But they sold millions of these things.  If it isn't working, the wiring may have come loose, the fuse to the unit under the dash might be blown, or something is disconnected.  if you go all through the FM dial, 0.1 at a time and don't hear it, it is time to get under the dash near the glove box and poke around.  Good luck.  If it were me, I would take all this gear out and put a new CD/MP3 player where the factory radio currently sits.
Jan 02, 2009 | Marantz ZS5300 6-Channel Amplifier
1,378 people viewed this question
 Grubhead
Grubhead
