Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
42" plasma tv turns itself off problem
Hi i have a 42" plasma tv which keeps turning off by itself. Sometimes it does it every 10 -20 min apart.Now and then it may keep going for a few hours then turn off. I have to leave it turned off for a while then i can turn it back on with the remote. It has a seperate unit that runs the tv.
The tv is about 10 years old.
Can this be fixed?
  • AmyZoe Sep 28, 2008
    We recently bought a brand new sharp aquous LC 37D44U TV - whilst watching it will turn itself off (no power- light on either) and then suddenly on. We have fully investigated that it's not a socket or our electricity supply issue. It's very strange. Any suggestions?
techman
  • 3130 Answers
SOURCE: TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Posted on Apr 02, 2006
  • 330 Answers
SOURCE: my panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Posted on Jul 10, 2008
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
SOURCE: plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Posted on Apr 14, 2009
SOURCE: Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Posted on Jan 03, 2010
I have a Samsung 42 " Plasma Model no: PS42Q96HD.
Hi, this could be a problem with the power supply in the tv, it is common especially on some Samsungs and specific repair kits are available quite cheaply if you have good soldering skills.
Usually this is caused by capacitors that have dried up and split, you can normally tell as the capacitors are bulging on the pcb, you can get them in a kit as I said eBay sometimes do them or you can buy them indivually from a good electronics components supplier, make sure you get the correct values for each!! marked on the side of the capacitors in xx/x V, xxx/x uF and 105oC. (the x's represent numbers)
The picture below shows the type of theing that happens, the brown ones are bulging/split on the top whereas the black one is fine.
High Voltages can exist in these sets, never attempt anything while plugged in and
if in doubt do not attempt it yourself and seek the advice of a qualified TV Technician.
Feb 10, 2011 | Samsung HP-R4262 42 in. Plasma Television
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
My 42 inch LG plasma got some water sprayed into the back of it yesterday. It has power however when you turn it on it switches itself off.
Take the tv aparts dries it out,might work again.Not than u will figure out what parts burn,power board or Main tuner signal board.
Jan 17, 2010 | LG Electronics 42 in. LCD Tv
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Tv shuts off and on by itself
I only hope you have connected the tv with a stabilizer or is it inbuilt? This might be because of Voltage fluctutations. Also, check the connectivity of the internal power card.
Regards,
HP
Aug 29, 2009 | Norcent Technologies PT4231 42 in....
On and off problems
Power Supply issue...i dont have a part number for this unit...but I'd replace the power supply first..........
Oct 14, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
488 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
