MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it goes from hot to cold every few minutes when the shower is on. Do I need a new shower, or can it be fixed?
  • 95 Answers
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Posted on Jul 11, 2008
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
I have a triton T90si that wont heat yhe water ,when i turn it up to 9 the water is only luke warm , could you please tell me what could be wrong?.ta.
Check your heating elements..Turn up all the way and listen to each element..You'll hear the one not working..Or you can put your hand by each one and feel for the ones that the coolest.Thats the one thats bad...
Apr 03, 2009 | Home
Triton T90si electric shower temperature stuck on hot.
It sounds as though the valve is not closing and opening properly. I would have a proffesional come out to have a look. I could also be the control board not working correctly or a combination of both.
Mar 22, 2009 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Heating & Cooling Logo
825 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
