Question about Toshiba Tecra M2 Notebook
  • 157 Answers
Re insert the HDD and try again or else go in the cmos if it is detecting or not..if not detecting,maybe it is loosen in connection or else the HDD is DEAD...
Posted on Jan 04, 2009
What's your problem?How to unfreeze the Port 0 Disk Status in the setup utility for a Aspire 5251-1513?
If the issue is that it does not see the hard disk on the 0 port ...and it gives you blue screen memory error means it does not have the ahci driver installed need to instal it as a 3rd party ...or ..go to bios settings (press f2 on start ) .select the hdd and under the settings for it ..disable the ahci for sata ..and select ide or ide compatible ..or sata as ide..depending on choices..
save settings with F10 and restart ..It will make the port functional ..
If you want to install with the advanced host controller interface ..than press f6 I think ...when it asks for 3rd party driver ..and try to load it from a usb device by browsing for it ..(in normal mode you need a floppy drive ) ..but it may work sure the usb is enabled in bios..
if it does not work ..than make a boot-able usb memory ..with the operation system ..and use it and insert the driver disk in the dvd drive ..and will work ..This way .when it asks for 3rd party will load the raid driver and the ahci driver ..and go on with the installing ..
Dec 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
I got a Toshiba Satellite A15-S1292 at a yard sale and immediately upon booting I received this message: IDE #0 ERROR Intel(R) Boot Agent FE v4.1.09 Copyright (C) 1997-2002, Intel...
Hi Jon.
Go into the BIOS confuguration by pressing the F2 key as the laptop starts up and set the BIOS to its default configuration. Save the changes by pressing the F10 key or save in the BIOS menu. The computer will restart so see if that has made any difference.
If you still get the same IDE #0 error then the hard drive is ready for failing. A replacement hard drive will not cost much at all.
Seeing as you have only spent $20 on the laptop in the first place you have got yourself a bargain there. Spend a liitle money on a new drive and OS then you could have a fully working laptop.
Jun 07, 2011 | Computers & Internet
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Toshia IDE #0 ERROR comes on the screen about 2 mins after starting then as follows is on the screen. .Intel (R) Boot Agent FE ver 1.10.PXE-E61 Media test failure check cable. PXE-MOF:Exiting Intel Boot...
This error is telling you that either one of three things have happened. 1. Your hdd cable has come loose or failed. 2. Your HDD has failed, or 3. the IDE controller on the motherboard has failed. You can check problems by trying a known good hdd in place of your old hdd. If bios sees it then it is the drive itself that is bad not the cable or controller. If it does not see the good hdd then try replacing the cable. If this fixes the problem then remove good drive & replace with your old hdd. Problem should be solved. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Toshiba (MK8034GSX) 80 GB IDE Hard Drive
Ive installed 160gb seagate 2.5 ide hard drive in my acer 2303lc when i put in recovery cd it says invalid system disk,replace the disk and press any key but when i press the key nothing happens ,its a new...
Do you have more of those recovery discs? are you sure you have the right one inserted?
I remember on my acer I first had to enter a system disc, then when asked the two recovery discs.
If your unable to get it working with those cds I would suggest you get your hands on a original windows xp or vista installation cd and install windows from it.
also have you tried to enter the boot menu on start up? when you power up it says on some corner of the screen what button to press to get it to open the boot menu and then select the cd/dvd rom drive.
Let me know if you need anything else.
Feb 20, 2009 | Acer TravelMate 2300 Notebook
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Aug 28, 2008 | Tablets & eReaders
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
Please check if the hard drive comes with small wire bridge inserted in master pins (not in slave or cs) all the disk come with three diff posisions, for this small bridge comes in colours black , white or blue. in ide hard disk.
after that please goes the computer to setup F2 and start in boot seccion and active only ide cdrom ( please don't use a hard drive or floppy options.) other systems with f12 and u can star with cdrom and insert the operating system(windows 98, Xp or vista and the machine starting the load againg. please check step by step for replace the missing information.
May 17, 2008 | Western Digital Caviar® WD300AB 30 GB...
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Toshiba Tecra M2 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
