Question about Canon PowerShot SD600 Digital Camera
Sd 600 CAMERA LCD PROBLEM
IT BEGAN WITH A SMALL BLACK SPOT IN THE MIDDLE OF THE SCREEN THEN IT GOT WIDE UNTIL THE SCREEN BECAME BLACK
  • Anonymous Jan 02, 2009
    Not sure mine has a butterfly in the right corner and it doesn't show anything looks like was dropped not sure if it was since there was 13 people at my house the next day tunred it on and that appeared .
    Problem Solver:
  • 13 Answers
I might make sure that the lcd panel and backlight are sufficiently attached. It is fairly easy to take apart the camera with a small screw driver. You might want to take it apart and push the two ribbon cables in tighter and then try again. (Make sure to take out the battery first)
images of the the dissasemby are on this page:
Disasembly of Canon Powershot SD.
Great disscussion of LCD assembly.
Posted on Apr 10, 2009
My tv has a black spot in the middle
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 24, 2015 | Samsung Televison & Video
My new lg 3d tv is closng on top bottom and sides is there anything i can do to cure the problem
Could you provide more information? What do you mean when you say, "closing?" Do you mean there is a black band around the picture? If so that means the original picture is recorded at a lower pixel density than your TV will display.
In the past most TV program signals provided a picture dimensions (in computer standards) very roughly 600 pixels wide by 400 pixels tall. What this means is that a picture of that pixel size will display as a small, squarish image slightly wider than it is tall on a (now) standard 1080p LCD television--which produces an image 1920 pixels wide by 1080 pixels high.
That would be nearly unwatchable (picture too small) except for the fact that most TVs compensate for the relatively small size of "standard definition TV (SD TV, as opposed to HDTV) by enlarging the image so that the top and bottom edges of the picture touch the top and bottom of the TV screen. This will leave black bands on either side of the picture. Some LCD TVs will automatically stretch BOTH dimensions of the image, which yields a distorted, "sqaushed" image.
All my comments above apply to both standard LCD and 3D-LCD TVs, by the way.
A more precise overview of the facts about TV picture size can be found here:
http://en.wikipedia.org/wiki/Display_resolution
Nov 23, 2013 | LG 42LW5300 42 Class 3D LED HDTV
Can the LED screen be replaced?
This LCD screen has been hit by a hard object, that is why there is a black spot. You need the screen to be replaced, a digital camera repairer can fix the camera for you.
Apr 23, 2013 | GE C1233 Digital Camera
Cannon SD 750 - when i try to take a picture a black screen appe
Think that you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Jul 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lcd screen has black spot inside, outside fine, takes pictures
you should replace the lcd screen from an authorized service center. or you can buy the lcd screen alone from ebay and find someone to replace it .remember
never open the camera unless you know very well how to replace it.thanks for using fixya. please dont forget to rate my solution
Jun 01, 2009 | Fuji FinePix J10 Digital Camera
Nchatta
it seems like if u see icons on lcd then sorry to tell u i think ur CCD is gone it seems like , but to make it sure first get the lens checked but iam pretty sure abt the CCD bcoz it is risky in impacts and jerks
Feb 23, 2009 | Canon PowerShot S45 Digital Camera
Canon s45 no image to lcd from lense
I have the same problem I went to the canon service department and they told me that its a common problem and the image sensor has to be change it will cost me 160.00 depending on the area where I'm getting it done so for me it's better to buy a new one.
Dec 31, 2008 | Canon PowerShot S45 Digital Camera
Can the lcd screen be replaced?
i have the same problem here. i sat down on my camera Doh! It need a new LCD screen, for sur, and i have a line whit a black/purple spot on the LCD. I open my camera and i separate the screen from the other part (white light) and i search instruction to continue the repairing, i can send photos of what it's look like, well im searching further instruction to replace the LCD screen.
Oct 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
Canon PowerShot SD600 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
