Question about Compaq (283983-001) Motherboard
Error 511 i have a compaq evo d31m and i receive an error on start of boot saying error 511-cpu fan not detected.... i replaced the location of the power fan with the case fan and i receved 512-chasis fan not detected what do you think of that please and do you have a solution for it.... ramzi
  • Anonymous Dec 03, 2008
    I got the same problem
    I turn on my computetr and a message shows up "511 CPU FAN NOT DETECTED" I think a problem with the wire but i dont want to mess things up
    The computer works
    but when i use media or large files the computer shuts and a red light start to blink
    Please help me
    I got Compaq Presario 6000
    Window Xp
    Intel inside Pentinium 4
    THanks
    PLZZ HELP
    The computer works
    Please help me
    Window Xp
  • 84 Answers
It means the 3 pins for that fan are not working on motherboard . I suggest you use the motherboard 3 pins for the chasis fan and buy a CPU fan with 4 pin setting that connects to your power supply ( much better current )
Posted on Jul 30, 2008
I had the same problem out of the blue. One day I tried to power up and I got the same error. I don't know if this is a fix, but all you need to do is press F1 and you are on your way. My fan is working fine!!
Rachel Appicelli
Posted on Jul 31, 2008
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
My compaq evo D500 sff blicks red light can't start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jun 18, 2012 | Compaq Evo D500 PC Desktop
are you the one opening your desktop computer?
If you are, check your cpu-fan connector pin if its properly connected to the motherboard
If not
check if your cpu fan are working if it didn't rotate replace it with a new one
Jul 26, 2011 | Compaq (283983-001) Motherboard
check fan if fan ok then check hard ware near fan jack sarfaysamandit fet or transister
if fix your problem click yes for vote
Dec 27, 2010 | Compaq (283983-001) Motherboard
What cause error code 511 cpu fan not detected
3 wire conductor fan. The 3RD WIRE IS THE fan sensor located in the fan's electronics this is malfinctioning come in tthe construction of the fan itself.
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
When i put on my computer, this message apear : 511-cpu fan not detected. I have a Compaq Evo D510 CMT and i use Windows Xp. Thaks for the help
This will likely be caused by a loose connection, if you look inside the machine there should be a cable running from the fan on top of your cpu to the motherboard. If thats disconnected or loose then plug it back in and all should be right with the world!
Dec 24, 2009 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Compaq evo n800v saying non system disc or disc error
You need to check in the BIOS to see if the hard drive is being detected. Other than that, do you have like a flash disk or a media card attached to it when booting up?
Mar 06, 2009 | Compaq Evo N800v Notebook
Fans won't start on my compaq evo
I suggest replacing the fans with new fans. Fans do expire and they need to be replaced.
Aug 30, 2017 | Compaq Evo D300s PC Desktop
COMPAQ Evo D310st
Please go to Bios setup and then Load the bios set up default, and restart the system.
If this not work, Please replace the CMOS battery maybe that battery is busted. and the do again"
"Please go to Bios setup and then Load the bios set up default, and restart the system. "
hope this help!
If not solve the problem please notify me, do not rate.
Feb 04, 2008 | Compaq (283983-001) Motherboard
Compaq (283983-001) Motherboard Logo
1,364 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
