Question about Xerox Phaser 8400 Laser Printer
Xerox Phaser 860 ink scratches off sooooooo easily
I have a refurbished Xerox Phaser and it seems that after the printer repair guy visited an put in a new clutch and put those cable tie things on the printer drawer pegs it's much more sensitive to the ink scratching off the page. Is it possible the fuser isn't getting so close to the paper? Or is this always a real problem -I just have to look at the page and the ink scratches off. -impossible to send out to clients it's just too sensitive to damage.
Any help greatly appreciated.
Cheers
Janeen
    President:
  • 2,072 Answers
An 860 has no fuser. That sounds more like either a maintenance kit or transfix roller needs replaced.
Posted on Jul 12, 2008
Phaser 860. I replaced maintance kit and it came up with sevice a
--> The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks. And use the link below for any other problems you may have.
Niallbt
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=117,E=0000000000024637030,K=5840,Sxi=17,command=restart,ques=user_type:4,ts=xo_legacy,varset=prod:860
Mar 08, 2009 | Xerox Phaser 8500/DN Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
PHASER 8500DN ERROR CODE: 09,038,46.8515
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Mar 08, 2008 | Xerox Phaser 8500/DN Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Tektronix Phaser 850 Service Fault 13.019.40
Most likely a bad print heat. One of the ink heaters is overheating.
Oct 08, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
115 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
