Question about Canon PIXMA MP160 All-In-One InkJet Printer
I was charged for service that wasn't done
On 7/9/08 I was charged for 2 service calls. First call, 64015 I was put on hold for 15 minutes and never talked to anyone. The second call 64016, I typed to GOPI 20, But the problem was never fixed, Please reverse the charges. Thank you
Fakju
canon pixma po 160 bekimi
Posted on Jul 11, 2008
Fakju
Fakju
Fakju
I bought a Dyson V6 Absolute Pro second hand. It won't hold a charge. Will a new battery fix this? Where do I buy one?
get the battery from e0bay or dyson retailer service agent
you got it second hand because it has problems'
batteries last 15 minutes on normal speed and 6 minutes on boost speed and take around 6 hours to fully recharge
Aug 23, 2017 | The Health & Beauty
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Washer won't do anything. It won't fill or spin. Nothing!!
If nothing is working at all it is probably the timer switch (dial you turn) they die. Not too expensive to fix. If you are comfortable with tools you can very likely do it your self. I know this because I paid a service to do it. When he was done, I went - Huh, that's all there is to it? It is just above Lego. If I remember correctly it took him less than 15 minutes to do it but I of course had to pay the minimum service call charge.
So just find a YouTube video for changing timers and you'll see what I mean.
Of course if it is not the timer you just wasted time and money.
I don't know how to confirm if it is the timer that is broken. Perhaps there is a diagnostic video....
Good luck
B
Mar 30, 2014 | Whirlpool LTE5243D Top Load Stacked...
My frigidaire dishwasher (FGHD2433KF0) is alternately flashing "Er" and "uo". What does this mean?
We called customer service and were put on hold for over 15 minutes. Glad I found the answer here.
Jun 28, 2011 | Frigidaire Dishwashers
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Jan 07, 2010 | Braun Health & Beauty
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Safe mode
Well I don't know if this will help your G1 but it did to mine. 1st If your charging it disconnect it 2nd Open your back cover and take out the battery 3rd Hold the power button (the red one obviously) for 15 seconds 4th Once your done with that replace the battery and cover Once you turn your phone on it should be out of safe mode otherwise call tmobile or whatever service provider you have they should help or call the android People. Hope this solved your problom.
Aug 11, 2009 | HTC G1 Smartphone
My t10 stopped working after i left it on hold for 15 minutes
just call customer service and ask them if they can repair it. I did and mines is working again. Plus you don't have to pay anything!
Jan 20, 2009 | Samsung YP-T10 Digital Media Player
Network unlock
Ok what you will have to do is call 150 from your t-mobile sim and go through to customer services , the quickest way of doing this is just to press 0 about four times and you will be put through . When you get to speak to someone ask for a subsidy pin for your handset . They will charge you £15 to unlock it and the code will be sent via post within about 2months. Doing it this way keeps your warranty or if you dont mind about the warranty you can go to a phone repair shop and ask them to unlock it for you standard charge is about £10 - £15 but can be done within the hour .
Mar 13, 2008 | Cell Phones
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
136 people viewed this question
old marine
old marine
