Question about LG KU990 Viewty
Problems working LG viewty with pc
Have managed to install the LG PC Suite on my computer, but when I connect the phone to the PC, and try to access my files, I soon get a runtime error message. This lists the location of the software on my PC and then states "This application has requested the Runtime to terminate in an unusual way. Please contact the application's support team for more information".
Hope you can help as it's so frustrating!
Many thanks.
  • 3 more comments
  • cervero1969 Jul 20, 2008
    cuando conecto mi lg 990 da fallo en la conexion bluetooh ya e desitalado pcsuite y lo he vuelto a instalar pero sigue igual...
  • Jayesh123 Jul 21, 2008
    I Install Software for LG KU990 I try to connect it but it not connecting to pc and I cannot download my pic from Camara Help me
  • dangerouskit Oct 20, 2008
    my pc cant open this software
  • Anonymous Oct 29, 2008
    the CD will not work
  • Anonymous Nov 25, 2008
    the same thing happens with me but when downloading music
I cannot use my LG990 as modem for my laptop. Is there a need to install program for vista or windows XP?
Please help
Posted on Jul 19, 2008
Probably the DLL file is missing, try installing from the net.
Posted on Jul 18, 2008
Lg KU990 screen frozen, how can i reset the phone??
Posted on Aug 06, 2009
2 Suggested Answers
SOURCE: LG Viewty connecting phone to PC
This is exactly the same thing that keeps happening to me and it is driving me absolutely crazy!!!!! Please someone HELP!
Thanks.
Posted on Jul 11, 2008
My downloader on my lg viewty is not working how do i fix it
Unfortunately it will then block you when you try downloading on your phone. So when it appears click options then 'start' to start any download.
If you still get an error message as 'Invalid descriptor', then you should install 'LG PC Suite' on your PC (Url: http://www.software112.com/products/lg-pc-suite+download.html), connect PC and phone through USB or bluetooth, then download the file in .jar format on your PC, then upload it to your phone through PC suite under 'Manage files'. You can then install the jar file directly when you select it in 'Your Stuff' on your LG Viewty.
Jul 05, 2010 | LG KU990 Viewty
Can not down load from pc using usb cable
what's the brand of the phone? normally every brand has its own way of connecting to the computer. nokia for instance uses nokia pc suite as a sync application. normally a cd with compatible software is delivered with the phone. if you don't have the cd, you can download the soft from the manufacturer's web site. install this software first and wait for the soft installer to ask you to connect the phone at the right moment to make a valid synced connection between the pc and the phone...
Apr 21, 2010 | LG KU990 Viewty
Unable to transfer files to lap top
First install the LG software on your laptop called pc suite.if you have done this then on your laptop go to control panel then system then device manager then check whether the port on which you connected your handset is working properly.If yes then go and check the settings of the pc suite you installed.Did you enable file sharing on the suite?
Jan 13, 2010 | LG KU990 Viewty
When I connect my LG Viewty to my PC it doesn't show up
Do you have a memry card? If so then you can access that by going into settings, phone settings, connectivity, usb connection, andchanging it to mass storage.
Jul 02, 2009 | LG KU990 Viewty
LG Viewty pc connection problems
Hi, I just had the exact same problem..
I tried like FOREVER and I even said, if this try doesnt work; i'm giving up, and then... it finally worked.. haha :) so, this is what I did.
(dont connect your phone yet but set your phone as data service) You open the program LG pc suite, and then click connection wizard > usb > and then here, you connect the both ends of the usb.. one end on your pc and the other on your phone, and then you press next. Hopefully it says something like Com Port Number and Phone Model. You click next and finish. So, now you are connected to the phone to your pc. To get photos to your pc, you click content. images. and copy and paste to where you like (pictures in your pc) and then your done :D this also goes to other files too :D if this doesnt work, then go to your right top corner box, close all applications and go to home screen! :D
I hope this really helped because I just learned it few minutes ago and I was about to scream because I tried so many ways. Hope this helped and Good Luck :D
Feb 16, 2009 | LG KU990 Viewty
Transferring data
its easy, just follow:
1. if you don't use memory card, skip the previous step and just install the LG PC SUiTE in the CD that comes with the Viewty, then connect your phone with the computer and in the LG PC SUiTE choose CONTENTS and there you find everything in your phone, just copy & past anything, this also works if you have memory card, but if you have memory card, the below method is faster and easier dealing with data:
2. if you are using memory card, copy all the things from your folders (images, sounds, videos...etc. ) from your phone to memory card.. then on your viewty, go to menu --> settings (fourth) tab --> phone settings --> connectivity --> USB connection mode --> then choose (Mass Storage) and then connect your phone with the computer and, here you go, you're all set and you find your memory card on pc :-)
regards
Jan 24, 2009 | LG KU990 Viewty
Lg kc550 drivers for vista?
1) On your phone, go to Menu -> Connectivity -> USB -> And change settings to "Data Service"
2) Plug in your phone to your computer and wait for Device Manager to say "Device has been successfully installed."
3) Go to your LG Phone's Software (PC Suite) and connect.
If PC Suite fails to find a phone,
1) Download another PC Suite at: http://www.fullandfree.info/mobile/lg-ku990-viewty-pc-suite-official-v20115/
2) Double check that your USB Driver is installed.
Nov 12, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KU990 Viewty can't open the contents in the lg pc suite.
HI All,
I had the same problem where i could not access the pictures etc off my viewty using a Vista laptop.
Now, assuming you guys are not bothered about the photo suite software itself, you can set the Viewty up to act as a mass data storage device (i.e. usb dongle etc). This enables you to view the full content of your Viewty, without using the **** LG software..
To do this...
1: Open up "Phone Settings"
2: Select "Connectivity"
3: Select "USB Connection Mode"
4: Select "Mass Storage"
5: Confirm by pressing "Select" at the bottom of the screen.
6: Return to home screen and connect to PC.
7: If PC does not automatically find the data, go to "My Computer" and look for a "Removable Storage Device"
If all goes well, you should have access to all your files!
Regards
Craig
Oct 16, 2008 | LG KU990 Viewty
My lg viewty
why doesnt my pictures from my phone transfer onto my computer??
Jul 15, 2008 | LG KU990 Viewty
What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
This will then alow you to connect to your pc;-)
Dec 22, 2007 | Cell Phones
LG KU990 Viewty Logo
732 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
