Question about Xerox Phaser 8560MFP Laser Printer
Phaser 8560 mfp code error
My machine is displaying error code 07,101,43:9957. Is there anything I can do to fix this or call for help? Also were do I get a code cheat sheet for this machine?
LeRoy
  • CoachKCP Nov 10, 2008
    I have a code 09.038.46.9852 - Any idea what it means and how to resolve it?
  • Anonymous Mar 31, 2014
    09.007.42:13474
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Posted on Jul 12, 2008
No display
You probably have to replace the display. It is a common problem.
Oct 19, 2014 | Xerox Phaser 8560MFP/SN - 30 PPM...
07 errors are usually a bad Process Drive Motor 005K12670, which is in the front right. Its big bundle of white gears get chewed up, usually due to cracked camshafts 020K14800 or 008K02160.
Afterward, there are important alignments, like latching the printhead in the disengaged position and timing the Process Drive.
Sometimes the screws strip out the chassis, and then you need to repair the mounts using a kit 655N00426.
Good luck.
Whit -- Item, Inc
Dec 30, 2013 | Xerox Phaser 8560MFP/SN - 30 PPM...
I have a Phaser 8560, when you turn it on it says "RAM ERROR" on the display, any advice
I would first try to inspect and possibly replace the ram. On the back of the machine there are two thumb screws holding on a metal plate. Remove the two screws to access the ram. If after replacing the ram the error continues you most likely need to replace the Electronics module (part# 084K35871). Here is a video that shows you how to replace that part. (video is of a non-mfp version so it is a little different but still similar)
Jul 06, 2011 | Xerox Phaser 8560MFP Laser Printer
We have a problem with a Xerox 8560 MFP with this error 37,008.44:34849. We don't known where is the problem. Can you help us ?
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Nov 18, 2010 | Xerox Phaserâ„¢ 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... oolivas@gruposion.com.mx cvalabacillascity@hotmail.com
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Code 39,003.40:53889
What you can try is shut down the Machine and unplug the powercord and unscrew the cable next to the powercord.
It's from the scanner.
after that reconnect both cable's and turn it back on.
and it should be fixed
Mar 12, 2009 | Xerox Phaser 8560MFP Laser Printer
I have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Mar 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 display error
There is a known issue with that display. Call 1-800-835-6100 and tell Xerox you have a problem with the diaplay, They should replace it free.
Jan 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
424 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
