Question about HP LaserJet 2420 Printer
HP 2420 Issue
HP Printer 2420 is connected to network but we are unable to take print out and also ping the printer. We tried changing the network cable, coneecting to other live LAN port still issue persists. Plese assist
  • Coss May 11, 2010
    Is the IP address of the printer set to the same subnet as the rest of the network?
I have an HP Laserjet 2420 printer. And it's really bothering alot, it has an error 13.06.00 and also 13.20.00. What shall i do? I tired to clean the falg sensor and replaced the end sensor, but still there is no progress. Please i need help ASAP.
Posted on Aug 12, 2008
  • 138 Answers
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Posted on Aug 03, 2008
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
How do I get my next book 8se android tablet to print
If you don't have HP Print Service Plugin and HP ePrint installed, make sure these two apps are installed. Go into ePrint and see if it 'sees' your network printer when you have WiFi on and you are logged on to the same network segment. If the apps cannot 'see' the printer in their selection menu, none of them will work until the connection issue is resolved. One other thing to try, download any app with network 'ping' function and try to ping your printer by its IP address from your tablet. If you cannot ping the printer from your tablet, you are either not on the same network segment, or there is some other connection issue.
Jan 05, 2015 | HP Tablets & eReaders
Showing ready but not printing anything
This appears to be a driver issue to me. Not communicating. As long as you can print out a test page from the printer, then the issue is communication. Try uninstalling and reinstalling and or change to a different print port. If networked, try pinging the printer.
Aug 23, 2013 | HP LaserJet 4200 Printer
Hp2420n printer does not print. Is connected directly onto a network. has ip address respons to ping.
please perform a power reset.
To perform a power reset you need to
1. Disconnect all the power cords connected to your printer (i.e the power cord and the USB cable.)
2. Press and hold the power button for 30 seconds. (this will remove the static energy if any accumulated in the printer.)
3. Connect the cables to the printer.
4. Restart the printer and try printing a page.
If it does not work please reinstall the drivers.
Dec 24, 2010 | HP LaserJet 2420 Printer
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
We have an HP Laserjet 2420 PCL 5e - it prints perfectly on regular paper but will not print envelopes. We have to manually feed the envelopes on the tray but it only prints gibberish. I have rebooted the...
This is not a printer problem. You have a computer problem. In ALL cases, the printer is told what to do from the computer, it does not report TO the computer.
Mar 10, 2009 | HP LaserJet 2420 Printer
HP 2420 keep printer wrong characters
This could be due to corrupt file or print job irrespective to file. This can also be an issue with the network sending packets or print spooler.
However, i would suggest to upgrade the driver to UPD (universal printing driver) PCL6
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?locale=en_US&pnameOID=412129&taskId=135&prodTypeId=18972&prodSeriesId=416419&lang=en&cc=us
Please let me know the next update.
- Nikhil
Nov 17, 2008 | HP LaserJet 2420 Printer
My HP LJ 2420 printer always lost network connection
fatuto,
I would recommend replacing the JetDirect card in your printer. What model is the card? The 600, 610 and 615 can be replaced with a newer 620. Make note of all of the IP address info before replacing the JetDirect card. If you send more detailed info, I can make sure that I send the correct info that you need.
Try this and let me know what happens. Binary Bob
Oct 29, 2008 | HP LaserJet 2420 Printer
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
LaserJet 2420 pdf printing issue
Hi within the driver printing preferences you are able to change the graphic mode if you do this it may help. Without seeing what you are trying to print cannot give a accurate answer so try this and get back to me if this doesn't work
Hope this helps you and please rate me
Thanks J
Dec 04, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
600 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
