Question about Denon Audio Players & Recorders
Have he KEF 2005.2 Speakers and I cannecting to the DENON AVR 2802 Amp. All Satellite speakers sound OK but there isn't ny sound from Subwoofer. I don't get he System Setup display on the Amp screen when I click the button on the remote to get the Subwoofer ON and OFF function on the screen. Can anyone please help.
  • naasash Jul 15, 2008
    OK. I will try this out and feedback to the thread.
    Thanks for getting back to me.
  • 151 Answers
Run a phono cable from the monitor out on the back of your amp to the tv then go to that input on the tv and then go to the setup menu on your amp ,also make sure you have the sub cable pluged into the sub preout and not the 6channel input.
Hope this helps.
CABLE GUY.
Posted on Jul 11, 2008
Denon avr 592 no sound
First of all check all the speakers. Maybe all the speakers gone out because of the loud blast. Also check in the tuner mode. Is there is any sound. If there is some problem in the avr then it will show the fault and will go into protection mode.
You can check the speakers with a battery from any one of the remote. Take the leads of each speakers and connect the lead to the battery terminals. If the speaker is ok then it will make a small cracking sound each time when you connect its wire to the battery.
Ajin
Sep 27, 2012 | Denon AVR-2802
I have denon avr-2802.. suddenly no sounds will come out but the power ok.. help me pls..
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2802-Receivers-manual/id/363bh830/t/2/
Is it silent for ALL inputs including the Test Tones?
Page 33
Function incorrect, Muting, Tape or EXT Input on when it shouldn
Feb 19, 2011 | Denon AVR-2802
No sound
check speaker conections. disconnect all the speaker wires and use one speaker that you know that works and connect it to each channel one at a time. most surround sound stereos will not go into surround mode unless all the speakers are connected so make sure stereo is in 2 channel mode to start testing. check all fuses sometimes amp fuse is seperate from power circuit and denon uses relays in 99% of thier units.
Dec 23, 2010 | Denon AVR-2802
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Feedback noise?
turntable and speakers are too close together----separate as much as possible.
-----floor is unstable and vibrate easily-------use cushion to absorb speaker vibration transmitted by floor.
Sep 18, 2007 | Denon AVR-2802
Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Jul 22, 2007 | Denon AVR-2802
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
No sound from my brand new speakers
I am assuming you have tried new speakers on used unit on both A & B choices. Have you tried your new speakers with old 2802? If they work OK with old unit, you have problem with amplifier in used unit. Take the used 2802 to a reputable shop and have it thoroughly tested. Perhaps it is just a loose connection.
Dec 12, 2006 | Denon AVR-2802
129 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
