Question about HP iPAQ RX3715 Pocket PC
Helo i have a problem
Stoping the use of mwdia plyer frezzed my ipaq due to that i toke off the battery when it was on when i put it back all i got on the screen is this note "align screen" i have no ide what to do it next?
  • 198 Answers
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Posted on Sep 27, 2008
My screen is not visible after I put my HP iPAQ HW6915 in my pocket.
very old device, nobody uses today, its obsolete really
not supported.
why ask here, , why not ask at
the real deal , HP. we are NOT HP, at fixya.
a new battery? tried?
Jul 28, 2017 | HP iPAQ hw6915 Smartphone
Battery clamp 2002 Chevy Venture
remove the bolt put a washer on the bolt then put the bolt back in place this should leave enough of the end of the bolt exposed to hold with plyers then put the nut back on and tighten while holding the bolt with plyers,use a washer that is not too big for proper application.
Sep 17, 2009 | Chevrolet Cars & Trucks
My hp ipaq 3950 freezed
press reset button with your stylus or take out the battery for a couple of minutes, put it back in and power on the device
Aug 21, 2009 | HP iPAQ H2210 Pocket PC
My iPAQ 5555 won't charge.
well that's really the problem when u go ur phone stocked for a weeks or two. i have my advice.. try charging yout battery manually. how is that? modification is needed. remove your battery from ur phone. and connect it to your charger directly.. (how is that? create a wire that can connect your charger to your battery. make sure u connect the right polarity) in this way your battery will charge for a moment and will give enough power to turn on your phone. because showing up that orange thing when charging up needs an initial power. so that is why. but still u can charge your phone. just live it maybe for an hour. it may work!
Aug 16, 2009 | HP iPAQ H5555 Pocket PC
HP-iPaq 2215 battery replacement
Hi, Jim--
When you take the battery out of an IPAQ you're performing a hard reset. I've got 4 different IPAQs and it does the same thing on all of them.
My solution was to back the IPAQ up using the internal backup program (back up to IPAQ storage) and then replace the battery, then restore the last backup.
Saved me a heck of a lot of time. It's been hard to remember to back up everytime I add a program or change data majorly, but it's probably the best thing to do.
Nov 22, 2008 | HP iPAQ H2210 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
IPAQ hx 2110
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
Dec 22, 2007 | HP iPAQ HX2110 Pocket PC
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
215 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
