Stadt J-90EI ducted heater sometime doesnt turn on. when reset sometime works other time a red light flashes 5 times which on the board says "Flame Det"
  • 1 more comment
  • Anonymous Mar 16, 2009
    sames
  • figaroddog May 20, 2009
    I have the same problem with the same model. Replaced the 4amp fuse and it lasted for a month. Now i've replaced the fuse again, this time it blows the fuse in a few seconds and that's it. Any feed back would be appreciated. thanks, Peter.
  • Stadt Heating and Cooling experts
    Hi, Our company specializes in Stadt ducted heating and cooling repairs. For any technical instructions or enquiry please visit our website on www.stadt.net.au. If you have further query please call on 1300 763 563.
Stadt ducted heater wont ignite
Posted on Apr 12, 2010
  • cameron465 Apr 12, 2010
    heater wont ignite pushed reset heater about 12 years old
Pilot light keeps going out on windy days and have to reset stadt ducted heater for it to ignite
Posted on May 13, 2010
ASTA09JEC Fujitsu model number operation light not on but time light (red/orange) flashing turns on then turns off automatically I have tried the reset button and turned the timer off on the remote
This is a serial signal error which means the outdoor unit is not talking to the indoor unit or vice versa. Most likely the outdoor board is stuffed but you need to count how many times the timer flashes to be absolutely sure which error it is. If you turn power off at the isolator for 5 mins then restart, this can sometimes clear an error caused by power supply fluctuations. If not, you will have to replace one of the boards. Indoor board allow around $200 - $250, outdoor board allow around $300 - $400.
May 09, 2015 | Fujitsu Heating & Cooling
Tip
How to fix your gas furnice
most gas furneses have a red light on circuit board wich is located on intake. turn heater off then have someone turn it back on while you watch the circuit board. count the # of times the red light flashes before it pauses. it will flash in a cycle. for instance it flashe 3 times then pauses for 5 secounds then flashes 3 times again on and on. look on the back of the panel cover,their will be a diagram, in the diagram their will be dianostic report that will include what that # of flashing red light and what it means. for examle 3 flashing red lights ps stuck open. that means pressure switch stuck open. replace the part and your back up and running.
on Dec 18, 2009 | Heating & Cooling
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
Goodman heater red light blinks 5 times is a blower heater, it says is the sennsor flame, i keep changing it but it keeps burning it over and over doesnt work
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering
Nov 05, 2011 | Goodman GMS90703BXA Heater
GMP125-5 four flashes replaced high limit and board. when powered up the blower comes on even with the T-SAT in off position.still getting four flashes from new board
when a high limit opens it tells the board that there is to much heat. The board shuts down the gas valve and turns on the blower. Find the limit that is open, sometimes you can reset them but most of the time you replace it. When you either change it or reset it, after power down then up, it should go back to normal.
Oct 06, 2011 | Goodman GMS90703BXA Heater
Our Stadt heater is not working. I have tried to turn the termostat off then turn it back on & that didn't work. I also tried to press the reset button for 5 seconds then turn the termostat back on....
o my friend i hawe a same problem in macedonia it hawe a mystake in elektronk part in airconditioner...and maybe is dthe outside part of split termik is not ok maybe ...
May 20, 2010 | Heating & Cooling
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Heating & Cooling Logo
1,726 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
