Question about Epson CX8400 All-In-One InkJet Printer
Expson CX8400 All-in-one printer
I just bought the above new printer that is compatible to my computer, but when I try to print the message says Cannot Recognize Print Cartridges. I have installed cartridges correctly.
  • 2 more comments
  • Nancy Dignan Jul 17, 2008
    I could not use any ink cartridge but Epson's...it will not recognize the cartridge no matter what I do.
  • mgfaglioni Aug 10, 2008
    JUST INSTALLED NEW CARTRIDGES< PRINTER TELLS ME >
    CATTOT RECOGNIZE INK CARTRIDGES
    YES THEY ARE EPSON
  • lovetokiss19 Aug 16, 2008
    when i try to hit "setup" to solve this problem it says "invalid operation". What do i do. this is the worste printer ever.
  • Harry Taylor
    Harry Taylor Dec 06, 2008
    Same printer, purchased same time from Staples UK. I have installed Black, Cyan, Yellow correctly with no problems before. I was almost finished printing 12 page Word document and it stopped saying I had run out of Magenta and Black. I could not get new inks then so had to abort print run and start agin when I had the inks.
    It now says that it does not recognise my cartridges- black, cyan and yellow after replacing Magenta only. So it does not print. I have not touched any other cartridge.
    Problem Solver:
  • 10 Answers
I had a problem with one of my Epson ink cartriges and called the company and they replaced it for free. Also many companies that sell knock off ink cartridges now have fixed the problem and now they are recognized by the printer.
Posted on Oct 29, 2008
You cannot enter Setup Mode while there is an existing Ink Cartridge Error being posted.
Mother ******* noobs
Posted on Oct 03, 2008
    Sergeant:
  • 287 Answers
Try this and post back results
Make sure the ink cartridges are installed properly.
  1. Press the Setup button, use the Expson CX8400 All-in-one printer - leftarro.jpg or rightarr.jpg button to select Maintenance, then press OK.
  2. UExpson CX8400 All-in-one printer - uparrow2.jpgsrc="http://i.fixya.net/uploads/images/uparrow2.jExpson CX8400 All-in-one printer - downarro.jpgrrow2.jpg" class="h_mi" /> or downarro.jpg button to select Change Ink Cartridge, then press OK.
  3. Open the printer cover, then open the cartridge cover.
  4. Press each ink cartridge down (you may hear a cartridge click into place if it was incorrectly installed the first time).
  5. Close the cartridge cover and the printer cover.
  6. Press the OK button.
Posted on Jul 11, 2008
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
Strange message epson cx8400
Your printer needs to be reset, the part that is near the end of their service life is the waste ink pad, it means that it is almost full, when it's full your printer will stop printing.
Jan 11, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson cx8400 printer "setup" bbutton not responding
lost disc and want to download my epson to this computer
Jan 04, 2010 | Epson CX8400 All-In-One InkJet Printer
Epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Mar 05, 2009 | Epson Stylus R265 InkJet Photo Printer
Compatible ink cartridges dx8400
Epson cartridges are microchipped.
Do your new cartridges carry the same chip?
If not, they will not work.
If all else fails, return them to the supplier and explain they are not recognised by your printer.
Feb 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer cx8400 All in one inkjet does not print well (ink is new)
have you tried to using the head cleaning? It will clean the nozzles inside your printer. you can check your manual how to do it.
Feb 10, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400
Your next step is dependent on exactly how the nozzle check prints.
Let me know
Aug 21, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson printer CX8400
Let me know if you find it--my computer and the printer show that my ink cartridges are full, but blank paper comes out when I try to print.
Jul 23, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 Blank Pages
i was having the same problem and just got off of the phone with tech support who fixed the problem for me,
go into system preferences
print and fax
there you should see the printer cx8400.
remove the printer by clicking on the - sign.
then re add the printer, by clicking the +
the computer will search for the drivers and install them.
that should have you printing like a champ.
hope this helps.
WW
Jul 22, 2008 | Epson CX8400 All-In-One InkJet Printer
ABOUT THE CX8400 EPSON WHAT IS MY PROBLEM I NEED HELP
Same problem. just bought the cx8400 today. I'm running the imac 10.5. It's feeding endless amounts of paper and can't cancel the job. Please let me know if you've found a solution. NO FRIGGEN PAGE SET UP option.!!!!
Dec 13, 2007 | Epson CX8400 All-In-One InkJet Printer
Epson CX8400 All-In-One InkJet Printer Logo
556 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
