Question about Canon MF3110 All-In-One Laser Printer
Error Message Insert Cartridge
My MF3110 was working fine all of a sudden I got 2 prints dark, removed the Cartridge and inserted it in after shaking it, Now it is saying Insert Cartridge. have tried to reset the cartridge many time and power reset also but still same.
Will this be fixed If I install a new cartridge ?
  • attygirl Nov 03, 2008
    I am having the same problem. Anyway have a solution?
    Problem Solver:
  • 3 Answers
I had same problem with my canonmf 3240 printer .which is similar to mf 3110.
and i have solved problem. and it works great.you can see how i have solve the problem
under my name GIRISH PATEL.and posted on 11-29-08.
Posted on Nov 29, 2008
Good luck - very little support for this printer in my experience. I am having the same problem and have yet to find a solution.
Posted on Jul 23, 2008
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
C4480 74xl
>Remove print cartridges, >Switch off the machine..>Remove power socket>Wait 10 to 15 mts, >Clean the cartridge & printer contacts. >Switch on the machine wait till message appears for the cartridges>Insert mono cartridge close the access door, check for the message>Insert color cartridge close the access door, check for the message> no error message.. diagnoses end> any error during the cartridge loading replace particular cartridge
Dec 27, 2011 | HP Photosmart C4480 All-In-One InkJet...
Cartridge error 1203
The 1203 error indicates either a communication failure between one of your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to fix the problem:
1. Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7. Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
1. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2. Remove the cartridges. Clean the cartridge contacts (How to Clean the Print Cartridge Nozzles and Contacts Manually).
Source: 1203 Error Message on the Lexmark X7170 All-In-One
Oct 08, 2011 | Lexmark X7170 All-In-One InkJet Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Message says cartridge error 1203 and it wont
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Feb 23, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge Error Message
Feb 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error message in printer
i have dismental all side covers along with front cover of ink compartment
and i found one of the lever attached with front cover and other end
attched to the inner mechanism was disconneced.once i hooked up the lever end
with inner mechanism, my problem has been solved.now my printer works good.
thanks
girish patel
Nov 23, 2008 | Canon MF3110 All-In-One Laser Printer
Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    My Hp PSC 1350v
    Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
    Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
    Canon MF3110 All-In-One Laser Printer Logo
    235 people viewed this question
    old marine
    old marine
