Question about Sony Ericsson Walkman® W880i Cellular Phone
Automatic shot down
Uatomatic shot down, i need to get the battery to open again.
  • 4 Answers
Http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250276275225&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dm38%26_nkw%3D250276275225%2509%26_fvi%3D1
Posted on Jul 29, 2008
Why do I get a burning smell and automatic shooting?
from the sounds of it just replace it with a better quality camera
Jun 28, 2014 | FUJIFILM instax mini 7 Digital Camera
My sony sybershot was not working now....i tried to recharged it but still its not open it .first i was scanning my picture and suddenly it shot down automatically /by it self.what possible problem does my...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Mar 13, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My Rebel XS is VERY slow after about 100 shots
Could be a card problem. How large is the card? Is it at least a class 4? Is it already full of pictures that need to be downloaded to make room? Has it ever been formatted in the camera?(This will erase it so download any pics first)
Apr 10, 2010 | Canon EOS Rebel XSi Digital Camera
Can not close the sun roof on the 2003 land rover freelander. It will not go down in the back.
the procedure for resetting the travel limits for the sunroofs of the lr3's is with the engine running, hold the sunroof switch to the open position until the sunroof automatically opens and closes and stops moving. this takes about a minute. i'm not positive that the procedure is the same on the freelanders, but it's worth a shot. if it doesnt work in the open position try it again in the closed position. good luck!
Nov 14, 2009 | 2003 Land Rover Freelander
Why does the battery die after only two minutes?
this may depend on what batteries are being used or some error of the camera or its settings.
1 when this happens try to open the battery compartment and close it again after a few seconds and see if this resolves the problem.
2 test the batteries in some other device such as a torch or other device and see if they work in that if so it maybe a problem with your camera or its settings.
3 if you are using regargeable batteries check in your camera setting if there is a battery type setting and ensure it is set to the same as the batteries you are using.
it is wise to use NiMh or other rechargeable batteries with a high rating such as 1000 or 1800 mAh normal alcaline batteries may not have the power to operate the camera for long.
note: if the flash is being used this will also run down batteries quicker also if images or video clips are being viewed on the camera this will also cause faster battery usage. also if the camera is being switched on and off after each few shots this may also reduce bettery life through lens extension and retraction, it maybe better to leave the camera on longer than keep switcing it off see if you have a power setting and set the camera to switch off automatically after 3 minutes if not being used then to keep the camera open if shot opertunities are still ripe the just half depress the shutter button to keep the camera live. this may help.
if this does not improve then recommend to replace the batteries as they maybe defective or the camera go to a certifed agent for testing.
Nov 13, 2009 | Polaroid iZone 300 Digital Camera
While updation computer got shut down cause of a prob automatical
get phone battery out ...and return it again ...it will open normaly.....
Mar 15, 2009 | Nokia N95 Cellular Phone
Flashing yellow light -- lens won't retract
Lens is jammed, you need to get it back on track. Gently push lens back in with a flat object to keep it straight, like a tabletop while powering it on. This may or may not work, but a jammed lens on these styles of cameras is common and renders the camera useless.
Dec 07, 2008 | Canon PowerShot A80 Digital Camera
Sony Cyber-Shot DSC-P72
Check the battery contacts inside the camera and see if there getting a good connection. If there spring loaded you might have to pull up on them slightly to get a contact going for charging. Look for corrosion as well.
Aug 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Ericsson Walkman® W880i Cellular Phone Logo
334 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
