Question about Canon PowerShot S1 IS Digital Camera
Black lcd screen when switch on - Canon PowerShot S1 IS Digital Camera
  • 13 more comments
  • vjandres Aug 21, 2008
    Perhaps it's some type of sensor but my lens doesn't "see" anything.  Everything else about the camera seems to be working except the major reason for having a camera - it can't pick up an image.
  • maroesjal Sep 08, 2008
    I have exactly the same problem. Seems like it is something with the lens.
  • HAJ41 Sep 14, 2008
    Sometimes LCD turns on others it doesnt. Seems to be a connection that is intermittent. Works OK when screen fires up
    Howden 41 @gmail
  • pmurrayvt Oct 01, 2008
    Same problem, have read it could be "ccd image sensor" - was a problem for Sony a few years ago, is it still? Has anyone had luck w/ Sony?
  • maclow130 Oct 24, 2008
    Same here... I was taking pictures the other day and all was fine. Turned the camera off, then back on a few minutes later to take a few more pics and the LCD is black and the lens won't see any images. Argh... Is there any way to reboot the software?
  • Anonymous Nov 27, 2008
    sAME PROBLEM HERE, TURNS ON THEN BLANK SCREEN, SOME TIMES I GET IMAGE THEN BLANK AGAIN :-(
  • rcoffeen Nov 29, 2008
  • DevilDuckie Dec 04, 2008
    I haven't used my camera since early summer.  Finally recharged the battery last night and now have a black screen.  I can see the menu, but am getting no picture on the LCD and the "picture" I pulled from the card is pitch black.
  • Anonymous Dec 05, 2008
    It was working fine and then now its all black we've even booght a new battery thinking that might help but not yet!
  • Anonymous Dec 10, 2008
    THe Last time I used my camera was Oct. 18 - and it was working great.  I tried to use it last night and the view finder and the LCD screen was black - and at times had lines. I tried to think back if I had dropped it or had left it in my car - but no...I treat this like my baby, have never dropped it or left it in any hot car or humid environment.
    I've read a few problems and see that Canon is offering a free fix, but I'm out the shipping cost - is this true?
  • Anonymous Dec 19, 2008
    I'll try the solutions described...sad...i really liked this camera...hope it finaly works !
  • The_lockhart Dec 20, 2008
    I have the same problem. Looked after th camera like it was a piece of glass. never dropped it or left it in my car on a hot day. Has been working fine. Gave it to a colleague to take my pic today and he found it had a black lcd screen and viewfinder. My wife has the same muddle and has had no problems with hers.
    I have tried the first solution. did not work.
  • Anonymous Jan 05, 2009
    I've the same problem too, we didn't use the camera for some time.
    The camera was stored properly. When starting up again, the screen remained black. It seems to work properly, you can take pictures but they are all black. The method in the TV-mode doesn't work with my camera.
    I'ver tried it for several times.
    I' am going to ask Canon in Amsterdam
  • Anonymous Jan 13, 2009
  • PORKBELLY Feb 14, 2009
    I HAVE MY LCD FLIPPED OUT AND CAMERA IN PICTURE MODE AND STILL HAVE A BLACK SCREEN. VIEW FIND IS BLACK BUT DISP. FUNCTIONS ON THE LCD SCREEN. IS MY INTERNAL LENS NOT OPENING?
Solution #1 is correct, and it worked for me. Only a couple slight variations for the solution.
The solution is:
1. Move the camera to TV mode(the wheel with AUTO,M,TV,...)
2. Set the exposure time to 15 seconds(15")
3. Take a picture. You should hear the shutter snap, but it can take anywhere from 5 to 30 seconds for the camera to reset back to the initial display screen.
4. Once it is back on the main display, open the battery compartment and remove/replace batteries (also, be sure to have full strength AAs in the device, as battery power may be involved with this issue).
5. Close battery compartment and repeat entire process.
I had to do this process about 10 times for it to work. Good luck everyone!
Posted on Jan 27, 2009
Comment posted on Dec 13, 2008 The problem is the iris is stuck. I don't know what cause this, it could be dust or wet air or both.
The solution is:
3. Take a picture.
4. After 7 seconds remove the batteries and put them back on.
5. Repeat the procedure until it works.
Note: You could also just quickly remove the lid of the baterries and put it back on.Also repeat the above several times until it works.
Posted on Dec 14, 2008
I had same problem but fixed it.
The nikon d80 menu screen and playback didn't work. Just remained black.
The shuttle release was slightly jammed with a tiny bit of grit. Removed the grit and the shutter release started working normally as did the menu button and playback. It had been intermittent too.
Posted on Sep 28, 2008
This is usually caused by a bad CCD sensor.
Posted on Sep 12, 2008
I had the same problem and couldn't find an anser anywhere, so i just hit it.
seems to work fine now :)
Posted on Aug 10, 2008
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Computer screen on Toshiba Satellite L745-S4110 worked yesterday. Will not come on, stays black with computer on. What could I have touched to make screen stay black?
There *could* be a video switching setup (usually FN and f8) that allows you to switch from LCD to External and "projector" modes. If these are not in the correct selection, your LCD will be blank because the pc thinks youre watching external vga connection. But it could also just be a bad connection to the lcd panel from the main unit
Jan 03, 2015 | Computers & Internet
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again.
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Black screen of death on a VIZIO LCD HDTC
check the warranty period
picture board problem so if not under warranty get a proper diagnosis done and a quote
Jan 27, 2018 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Black line down right side of screen
turn off laptop.
press and hold on the D then press Power button.
during the LCD BIST test check if the black line down right side of the screen is visible. if yes LCD needs to be replaced. if not connect your laptop to an external monitor check if the black line display appears to the ext monitor, if yes uninstall / reinstall video driver if fails replace video card or if it is built in replace motherboard.
if no ext monitor available then run PSA (press and hold Fn key then press Power button)
check if the black line is visible. Check also in BIOS is black line is visible, if yes then uninstall reinstall first the video driver if fails replace LCD.
Oct 11, 2009 | Dell Inspiron 9200 Notebook
Acer aspire 5100 black screen
pls check the RAM i think it is a RAM malfunction it has nothing to do with lcd if ur system does not bootup and u dont see any hard disk activity as loading OS files while the screen is OFF black then try changing RAM , or if u have 2 chips of RAM try one at a time in one slot that is the upper most or get another one to try with same specs
aslo try connecting the monitor out this will trouble shoot ur LCD screen and vga
pls let me know if i can help more , and rate me FIXYA if i fixed
Mar 09, 2009 | Acer Aspire 5100 Notebook
I have a Philips 19" Lcd When i swithced it on everything was fine until about 5 seconds later the screen went black. I have found that if i switch the monitor off and then on it works ok until...
A 19" Philips LCD prefers a setting of 1440X900 if you are too far off this it will turn itself off.
Right click on the desktop, go to settings and set it to 1440X900 and then go to advanced and make sure the refresh rate is set to 60 Hertz. Shining a flashlight on the screen will help you see.
There other thing that might be causing this is the setting on the monitor itself. Press the Menu button on the LCD and adjust the brightness and contrast.
If all else fails, contact Philips. This is a premium brand and it comes witha 4 year warranty.
Oct 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
ECS Elitegroup lcd screen turns black after the unit is switched on after a time
It would be either the backlight behind the LCD or the inverter board capacitors going out, my suggestion buy a new LCD screen.
Mar 08, 2008 | EliteGroup ECS A535 Notebook
Lcd screen
no ligth in led power on , slightly black screen seen on lcd
Dec 09, 2007 | Aiptek DV4100M Camcorder
Canon PowerShot S1 IS Digital Camera Logo
200 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
