Question about Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner
The bottom filter under the canister keeps popping out everytime I vacuum. This is really annoying. The bottom looks sort of dirty but I'm not sure how to clean it.The top looks very clean. I know I need to clean the filter in the canister but why does this one that is curved and says "Filter made with HEPA media" keep coming out?
  • 438 Answers
This is a pretty clear indication that your filter is clogged and needs to be replaced. HEPA filters are different then say pre-motor filters, or sponge filters. Because they are usually the last filter before the air is exhausted, it's usually catching very tiny microscopic particles. Because of this, trying to determine if the filter is dirty or clogged can be difficult, if not impossible on HEPA pleated exhaust filters.
The fact that your filters continues popping out, indicates that the air is not being able to pass through the filter as it's supposed to, and is instead the air is having to try and find a different way to escape, causing the force of the back up of air to blow the filter out.
I think if you replace this filter, it should fix the problem completely. Because this filter is designed to capture microscopic particles rather then large particles, washing this filter, or getting it wet is not advised, and wouldn't be an effective way to clean it. You really will need to replace the filter soon, but if you'd like to try and prolong the life of your filter, you may use an air compressor, and blow from the top of the filter (the area that looks clean), and clear the microscopic particles, and dust out of the filter this way. If you suffer from breathing issues, asthma, or allergies, I would highly advise against doing this without a mask on. The dust that will come out is extremely fine dust that can cause people with the above conditions to suffer greatly. Doing this outdoors is highly recommended.
An air compressor can certainly prolong the life of HEPA filters, but again, sooner or later you'll need to replace the filter.
If you're in need of buying one of these filters, you're in luck! We carry these filtes on our site, and they are in stock. Here's a link back to the filter on our site if you need to order one. We offer free shipping, 60 day returns, free return shipping, and no restocking fees. Please feel free to reply to this solution by using the comment box at the end of this solution. If you found my solution to be helpful, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated by the FixYa community, and is really what keeps repair professionals like myself to keep answering free questions, and not just the premium questions which we get paid to answer.
http://www.govacuum.com/10662-Hoover-303172002-Windtunnel-T-Series-Replacement-HEPA-Filter-Cartridge.aspx
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Jan 07, 2011
    New Friend:
I also have hoover vacuum uh70120 with HEPA filter that keeps popping out, it was little bit dirty so I cleaned with air compressor, looks like brand new, Put it back and still the same issue. I bought a new one and still the same issue. Looks like this is a design flaw, the plastic clips at the end of the filter snap in too lightly, they should be very snag instead. Should I use a rubber band to hold it in place.....it is ridiculous.
Posted on Sep 07, 2016
    New Friend:
I too am having problems with the hepa filter popping out and mine is brand new and clean. It cant be clogged up because this is just the 3rd time its been used. I have to keep stopping to put it back in. How can I fix this or do I need to take it back?
Posted on Jan 07, 2015
I cleaned the filter and emptied out the canister from the bottom and now the dirt comes out on my filter and not in the canister?
The first place the "dirty" air enters is the top chamber of the canister where it traps the bigger stuff.
The canister has two clean-out doors so make sure you open them both (top and bottom) or you could have problems.
Nice thing about the Shark as it has a number of clean-out points starting at the base of the hose where it enters the bottom of the vac. to the beater brush (on the bottom of just behind the brush assembly). Good luck!
Mar 16, 2015 | Shark Navigator Bagless Upright Vacuum
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Heppa filter keeps popping off when i turn on the vacum
Hi There, 99 times out of 100 this is due to the exhaust filter being too blocked for the air to actually get through. What happens is that the pressure in the motor increases and effectively blows the filter and filter cage clean off. If you have a look at the underside of the filter I would bet that it is very dirty and you will need to buy a new hepa filter
Oct 12, 2013 | Electrolux EL7055A Bagless Canister Vacuum
Dust goes to filter
is the canister sealing properly? The air enters the canister under high pressure and it should slow down greatly in there so the heavier (dust) particles will fall to the bottom of the canister and the air should then pass through the filter under a reduced pressure. If the air is easily escaping the canister area without slowing down the dust cannot settle. It should look like a cyclone in the canister, if it's not swirling in one direction but rather bouncing around, look at the inlet to the canister for build up or an obstruction also. If the canister is not sealing the the air will remain moving rapidly and carry the dust along with it. I would also check your filter for a tare along the seam.
Apr 03, 2013 | Dyson DC08 Cylinder Bagless Canister...
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
This silver metal triangle shaped thing popped out
I think it's a spring that goes on the bag holder itself... You have to sort of pop the bag holder up from it's hinges and see a little tab stick on the bottom, in the middle, pointing sideways. There's a little groove that the spring is supposed to line up with on one side, and if it's not in that place you put the spring on backwards and have to turn it around the other way so the end lines up. Then snap the holder back in, and make sure the spring is pushing against the vacuum so when it's in place, the holder pushes the bag up towards the lid. The spring is to keep the bag pressed up to the air intake, and doesn't push down very much.
Jan 14, 2010 | Miele S318 Bagged Canister Vacuum
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hepa filter does not rotate
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Mar 16, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Feb 06, 2008 | Hoover Commercial C1660-900 Bagless...
Hoover UH70120 WindTunnel TSeries Rewind Bagless Upright Vacuum Cleaner Logo
6,799 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
