Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Control setting not lighting up anymore
After 1 year, the control setting is not lighting up anymore. Actually, it lights up once a week, without notice. So that tells me the light is not burned, but why doesn't it light up all the time....
  • 74 Answers
Check the electrical connector at the bottom of the freezer door for corrosion
Posted on Aug 28, 2008
Westek SLC6CFL programming instructions
Copy following link for Westek outdoor socket timer instructions:
http://waterheatertimer.org/pdf/Westek-SLC6CFL-timer-instructions.pdf
Jun 27, 2012 | Ace Hardware AMERICAN TACK 3236858...
I updated my PS3 because it told me it would not run without and update and now it doesn't recognize the controller... CECHP01 used the latest update 3.66 (it asked for 2.76 or later.)
PS3's will sometimes loose their connection to the controllers. I have always fixed this problem with these steps:
1. Make sure the system is off (red light)
2. plug the control in with the usb cable
3. press the PS button in the middle of the controller (this will let the console relearn the controller)
4. once the lights on the front of the controller are not blinking red anymore, and have a single green light indicating which player the controller has taken, hold the PS button and turn off the system
5. once the system is off, unplug the usb cable
6. the controller should work without the cable now. (check by pressing the PS button to turn the system back on
Controllers will lose their connection to the PS3 when they die completely, during updates, power outages, etc. I don't know what exactly causes it, but I have had to do this process several times since I got my PS3.
Thanks,
John Vickers
Aug 12, 2011 | Sony Playstation 3 (PS3) Console
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
1. Turn on the device that you want to set.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
at least 3 seconds until the red LED lights up solid red.
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
LED light will blink once and then remain solid red.
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times.
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
to program powers off, then you have found the correct code. If the device does not
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
On my 1994 S-10 Blazer, the AC/Heater stopped blowing on high speed about 2 years ago. By switching the speed control quickly back and forth, sometimes High would work. But not anymore. I had the A/C...
Sometimes the electrical connecter burns on the back side of your switch. You can get just the switch and replace it and repair the connecter when possible.
Aug 12, 2010 | Chevrolet S 10 Cars & Trucks
My 3 1/2 year old ge spacemaker over the oven microwave with vent fan has stopped rotating inside.
Did the cooktop lights recently fail?
If so, then the problem is probably on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Whirlpool sise by side thats about 4-5
you need a new control panel, if your light bulbs blow out it surges the control board and ruins the control board and your symptoms of no lights and temp control points to the control board
Nov 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
118575 remote stopped working batteries are new lights light up but wont control tv or satellite anymore even though it just worked
The receiver more than likely received a software update or reset itself and reset the codes to the receiver and tv. We will need to set the remote address again and run a power scan to control the tv. Using the front panel buttons on the receiver press the menu button twice. This will put you at the system info screen. You will see the remote addresses for tv 1 and 2. They will probably both be set to 1 if the receiver reset. Press and hold the SAT button on the TV1 remote until all lights across the top light up and release. Now key in a two digit number between 1 and 16 (for 1-9 precede that numeric with a zero) now press the pound key at the bottom right of the remote numeric keypad. The SAT button will flash three times and press the record button until the remote address on the screen displays the one you entered. The receiver should now be able to be controlled by the remote. Now we need to do a power scan - press and hold the upper left TV button until all buttons across the top light up and release. Press the red TV button and release, The TV button should be lit constantly. Now press the channel up button slowly until the TV turns off. Once it does press the channel down once and then cannel up to see if the TV turns back on. If it does press the pound sign. Now press the record button and you are back in business. If you have further issues let me know. Thanks for using Fix Ya.
Apr 03, 2009 | DISH Network IR Remote Control
Cruise control fails to engage on '03 ford sport trac
Th is is how I fixed mine! Down on the brake pedal there is a small plastic box about 1 1\2 * 1 1\2 in size. It's called the brake stop light, I think. This part disengages the cruise when the brake is pressed. Not sure on it's other uses! Remove the clip from the part where it attatches the the pedal. For more working room you can remove the plastic keeper. The box has three keepers on it. Pry them out gently to remove the top. Two of the copper pieces inside will have contacts on them about the size of a match stick head. Take them out and clean them with an eraser. This solved my problem, I hope it solves yours. Let Me KNOW!
Nov 21, 2008 | 2003 Ford Explorer Sport Trac
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
54 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
