Question about Indesit W 123 Front Load Washer
WG1130D Hi I have a similar problem with my WG1130D, the dial stops after a little while. The water does enter the machine and it starts to turn for a while then the timer sticks. The water appears cold also and i took off the back to check and the element housing is cold. Could a faulty element and the water not heating stop the cycle?? If so can I check the element with a multimeter and check its resistance for example to see if it is faulty? Thanks
  • armstrk Jul 22, 2008
    Thanks for response I got a new element and changed it. That sorted the problem, now working again 100%.
    I checked the element with a meter and it was open circuit, i.e. no reading across the element.
    Thanks again
    President:
  • 1,462 Answers
If not heating, will stick in cycle.
remove connections from element and check for continuity with a multimeter
Posted on Jul 16, 2008
  • douglas smith Jul 23, 2008
    glad it worked
    doug
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Dec 18, 2016 | Candy Washing Machines
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
see this causes and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 25, 2012 | Washing Machines
Hi! re BOSCH washing machine WET 2820 Program will start, and then for 30 secs approx start normally, water starts to enter the drum. Then it stops, nothing happens. I have cleaned the soap dispens
BOSCH washing machine WET 2820 This video will show you how to change the door eal washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 07, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Ge front loader hold start button the cam dial starts to turn and the drum turns a little but no water and then stops help
'...but no water'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 01, 2011 | GE WSXH208A Front Load Washer
Machine will not spin dry the clothes and stops mid cycle
Hi ricevans,
Check to make sure that the filter in the pump is not clogged. Open the little door on the bottom and have a towel ready as there will be some water in the pump. Turn the dial slowly and let the water seep out. Pull out the dial and if you see any kind of debris, (lint, coins, etc..) Clean out all of this and put back into place and your machine will work fine. The reason for this is that the pump is designed to pump out all the water in an 8 min cycle if it exceeds the time limit the machine just stops. Hope this helps you out.
Feb 28, 2011 | Whirlpool AWM5104/1 Front Load Washer
Water leaks from underneath Indesit WG1130d washing machine.
I had a problem like this and it turned out to be the hose that carried the water out to the drain was overflowing the drain pipe.
Make sure the P trap in your drain line is open and clear. A plumbers snake, draino, or a high pressure nozzle on your garden hose might help to clear it.
Oct 04, 2017 | Indesit W 123 Front Load Washer
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Water entering the machine and not stopping
Hi, check water solenoid valve again, or give it a little tap, sometimes they get stuck, when you remove plug, if you had a timer problem, water would stop, your water solenoid valve have to be faulty, if you purchase it, you should return it. if it were a used one it's defected. the only other thing is if you have high water pressure in your house/building, probably that could force it open, but most unlikely, you should check, but first check water solenoid valve, it could be a mechanical fault, inside of water solenoid valve, you can remove water solenoid valve, put it apart and make visual check of plunger and all other parts inside of valve, if same problem continues, replace water solenoid valve. let me know, if your problem continues. Good luck.
Aug 19, 2009 | Washing Machines
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
140 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
