Welcome to FixYa.
Try this link of my solution for this issue...it is very common.
http://www.fixya.com/support/t7367730-f_21_error_displayed
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Hi
F24
is a water temperature sensor error. You have to unplug the washer and check
the water temperature sensor and its connections, if that is fine then check
the resistance of the heating element and the part that is bad should be
replaced. Hope this helps...please post back for further
assistance.
Daniel
Hello &
Welcome to FixYa
F21 error code is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
