Most of the times the dishwasher door will have a frame system. With 2-3 screws on the left or right side of the door removed, one side of the frame can be removed and the panel on the front removed. If you have a dishwashre door that wraps around the sides, things become more difficult. There will be screws on the left and right and also on the bottom. Furthermore sometimes the wires/cables to the control panel have to be disconnected as well. Makle sure you keep the screws in a safe place as there will be 10+ of them. Once the door is unscrewed, you may also have to unhook the spring that keeps tension on the door. If you have a frame system and you want to just replace the color then you have an easy job ahead of you. (go to applianceart.com for panel options),but if its a "wrap around" door panel then it is much more difficult. I suggest, if you are tryign to change it to stainless, that you order the faux stainless material that goes over your existing panel. it may save you alot of time and headache.
There are two ways to change the language of the front-panel menus
and messages:
No matter which method is used, the language selection menu should
now appear on the front panel.
Figure 1: Select Language Menu
Highlight the preferred language, then press the Select key to change the language.
Hope this helps.
Thank you for posting..
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
