Question about Stoves 600SiDOm Gas Kitchen Range
Stoves df 600 sidom
Mornin ,got a problem with this cooker when you turn the oven stat on its fine butintermittently it wont turn off. i checked the position of tap spindle and thats ok .the oven does stop heating but the indicator light and fan stays on im sure its a micro switch or stat problem but i cant find a iring diagram on the web
  • Anonymous Mar 16, 2014
    I have delonghi dsc90 df oven doesn't come on neither does fan when switching on
We had ours fitted by a Stoves engineer who said he had the same cooker. He also told us that sometimes the fan will stay on after you have finished using it. The reason is, there will still be heat coming from the cooker or grill after use. For that reason, the fan stays on for a bit afterwards. Its just a safety precaution so that the knobs dont get too hot.
Posted on Jul 20, 2008
Replace cooker element in delonghi dtc 90 df fsd
Kirsty
Open the oven lift the element and pull back. I have replaced many in multiple brands but make sure you get the correct one by getting you stove model info.
Sep 11, 2016 | DeLonghi Ovens
Changing the light bulb in a stoves df 600 si oven
STOVES n600 is a squair glass window which prizes our from the bottom. It looks simetrical but only goes back in one way up
Oct 08, 2012 | New World Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have a stoves newhome GL616 cooker that just
Hi I have a gl616 cooker when turned on and flame on gas mark 9 the flame dies down then it turns off, any reason why this happens have replaced the fan,problem still occurs.
Jul 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
Need instruction manual for stoves heritage 720EF cooker
Supply an email address and I will validate it on my BT Digital Vault to give you access to take a copy of the Handbook.
Nov 03, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves 600SiDOm Gas Kitchen Range Logo
642 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
