Sony Walkman cassette player WM GX100
The belt came out from the flywheel (belt to be replaced)
SOURCE: URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
Posted on Sep 14, 2008
  • 11 Answers
SOURCE: Sony Walkman cassette player/recorder will not rewind the tape
Fat chance to repair yourself! we repair that WmD6c but very hard to do!
Posted on Feb 26, 2009
AmrSabri
  • 59 Answers
SOURCE: my sony walkman
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Posted on Apr 26, 2009
caroldon
  • 17130 Answers
SOURCE: how to replace the drive belt on the sony walkman
Since this is a very small player what is important is to be very careful and delicate to open the rear cover and do the repair. The printed circuit board has to be removed and moved up carefully not to damage or detach wires. Now remove the capstan cap and take out the old belt, check the size with the new one and if OK run in the same direction you had taken out. replace the lid and the pcb carefully and fix the wires according to the same pattern so as not to touch the belt and drives. Now put in a cassette and test. If it works ok with the speed close the rear cover. clean the headd, the rollers and the transport section . Now your tape has been serviced and must work well. Hope my advice helps you . Good day
Posted on Jul 22, 2010
issikiki
  • 563 Answers
SOURCE: i need to have a user manual for a SONY
Hello.
You can get the manual here.
Posted on Aug 11, 2010
Tip
Player too slow
if the walkman is too slow, try the a new belt, batteries and cassette.
on Jun 07, 2012 | Sony Walkman WM-FX141 Personal Cassette...
I need drive belts for Sony Walkman AM-FM tape player
call 1-800-488-7669 for walkman parts mon-fri 8:00am - 12:00am ET sat-sun 9:00am - 8:00pm ET
Feb 04, 2011 | Sony Walkman WM-D6C Personal Cassette...
My unused WM-FX 195 doesn't play cassette
Fault with the drive belts, remove rear covers and take sample belt to buy and replace. Might be difficult to get them but in old stocks.
Aug 30, 2010 | Sony Walkman WM-FX193 Personal Cassette...
It wont play tapes
If the walkman comes on but just wont play tapes then more offten then not the belt has broken or clutch has worn out and will have to be replaced.
you will have to open the walkman up in order to do it, you can get a new belt from any electronics parts supply store (not radioshack) there usualy around $1 and are easy to put on.
Jul 19, 2009 | Sony Walkman WM-FS399 Personal Cassette...
Tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
Motor is ALWAYS running on this thing?
No not normal motor shuts off when not in play or other drive functions! we repair that model! want to sell it?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Tape fails to return to cassette when cassette removed.
I'm an repairer of electronic and micromeccanaca I have repaired many walkman analog (WM-D6C, wm-dd9, etc.. Improve your performance if required and if possible) and many like dat walkman Sony TCD-D3. I just started to repair even for those who come out of Italy. If you would contact me to explain the problem better I'll try to help. Email: doctor.walkman@gmail.com Sono un riparatore di elettronica e micromeccanaca ho riparato analogico walkman molti (WM-D6C, WM-dd9, ecc. Migliorate le prestazioni, se richiesto e se possibile) e molti come dat walkman Sony TCD-D3. Ho appena iniziato a riparare anche per chi si trova fuori d'Italia. Se vuoi contattarmi per spiegare meglio il problema cercher? di aiutarti. Email: doctor.walkman@gmail.com
Jul 29, 2008 | Sony Walkman TCD-D100 Personal Cassette...
70 people viewed this question
 Grubhead
Grubhead
