Question about Acer Aspire 1414 Notebook
Screen stays black
Our Acer's screen stays black when we start the computer. The computer itself seems to start normally but the screen displays no image?
The computer is about 3 years and very dear to us as my fiancée is doing her thesis with it. Help would be greatly appreciated :)
  • Kmasse Jul 11, 2008
    Thank you very much for your helpful and quick answer! :*)
    I forgot to tell you that our computer is a laptop (Acer Aspire 1414), which complicates things.
    I will try to find a different monitor to see if it works with that.
  • 96 Answers
Try using a different monitor if you have one available, or disconnect the monitor from the computer and then turn it on. If you see a logo or color bar or message saying no signal, then your monitor is OK and you should take a look at your video card.
If you suspect your video card, there is very little you can do with a no video situation. but one thing you can do is to remove the video card completely and wait for a few minutes. then put it back in and try to start your computer. This is just in case you have corrupted video memory keeping it from functioning. otherwise, replace the card.
In the case that your video is built into you computer, buy a new card and disable the onboard video in the BIOS. That will take some browsing in the BIOS setup, but it shold be fairly easy to find. once it is disabled, the new card will be able to function and you should be ok from there. Otherwise, it's motherboard replacement time.
Posted on Jul 11, 2008
  • Bob Duker Jul 11, 2008
    OH, and if you don't see any of those things on the monitor, replace it.
Acer aspire 5100-3583 boots, screen is on, but
Dec 07, 2017 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Monitor displays black screen
when you power up the computer pres F8 key thene enter in safe mode.then uninstall vga graphic driver then reinstall it in normal mode.
Aslo check your screeen resolution settings it should be 1024*768
Jul 22, 2009 | Acer Aspire 5315 Notebook
Computer is on, screen stays black
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
for parts, repair service and DIY info.
Jul 04, 2009 | Acer Aspire 3690-2196 Notebook
Screen stays black
when you first power on do you see bios info on the screen? if not (since its a laptop) chances are onboard video card maybe bad.
if you do see it do you see windows start showing at all? in either case wether you see it or not try booting up in safe mode (start hitting F8 key right after bios goes away) and if it works. if you are able to see screen in safe mode chances are drivers are corrupt i would say go in device manage and uninstall display adapter and restart computer and let it boot normally and see it make any difference... if it works get new drivers from manufacturer and install.
let me know if it helps.
Apr 17, 2009 | Acer Aspire One PC Notebook
Acer 5920 screen black out
If movement is affecting performance of a device, most possible chances are you have a loose connection. Please contact the vendor for a replacement of the LCD cable / the LCD itself as the case might be
Jan 11, 2009 | Computers & Internet
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Acer Aspire 5100 Notebook
Acer Aspire (1414) screen stays black when started
It's look like your laptop have a problem called "NO POST".
motherboard, cpu or memory can cause this problem.
To diagnose it, reseat your memory first and after that turn it on.
if it still no post.
use only 1 memory and turn it on, if still same,
Try to move your memory and seated to different slot and turn it on. if it still same, it's mean your motherboard/cpu is bad.
good luck
Jul 11, 2008 | Acer Aspire 1414 Notebook
Acer Aspire 1414 Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
