Question about Microsoft Wireless Optical Desktop Comfort Edition
Wireless mouse not working
I have a microsoft wireless mouse 700 which was working fine until I pressed the connect button behind it. Now, it just doesnt work. I tried uninstalling it from the device manager, but no luck. Someone pelase tell me how to get it working again.
  • arathi Jul 15, 2008
    Thanks a lot. It works fine now that I pressed both the buttons simultaneously. :) Thanks.
We had the same problem and just found this solution, we don't know how long it will work for!
hey - i think i actually found the answer.
there is a reset button on the bottom of the mouse.
and there is a reset button on the receiver that plugs into the USB. click them both and vuualla! - it works again....
we'll see how long this lasts.
(most blogs tell users to just exchange the set, it's poorly designed)
good luck -
Posted on Jul 12, 2008
How do you replace battery for a microsoft wireless mobile mouse 3000
I'm not sure about your exact model, but on my microsoft wireless mouse (model 1023) there is a silver button on the front that you push to release the plastic piece on top (push the button and hook the top plastic piece with your fingernail and lift up). There will be a battery compartment for 2 AA batteries. If there is no button release, look on the bottom of the mouse for a button or release flange. They are replaceable, so just investigate and play with it until you get it to open up. Good luck, and hope this works!
Jun 02, 2010 | Microsoft Wireless Mobile Mouse 3000
For 2 years years I have a Microsoft Desktop Receiver 3.1 with a Microsoft Wireless Laser Mouse 5000 v1.0 and a WIreless Laser Keyboard 6000 v2.0. Things were working fine until this morning when the...
Goo0dness, Had this myself just last week. Fortunately I had the old keyboard and mouse and plugged it in to get access. I deleted the wireless keyboard from device manager. rebooted the machine, quickly changed the mouse and keyboard back to the wireless one and it all came back on. saved me buying a new one. Hope this works for you.
Please rate my help++++Thankis for using FIXYA
May 15, 2010 | Microsoft Wireless Optical Mouse USB...
Microsoft wireless keyboard 700 v2-0 not working
Your keyboard MS 700 v2.0 needs a USB receiver to work. They are pert of set. You may also have a wireless mouse MS-700 that is also part of this set.
1. Do you have the receiver ? This has a USB connector that must plugged in to your PC's USB port
2. Are the batteries in your keyboard dead ? If so change them for fresh ones
Then proceed with the instructions in the Quick Start Guide which can be found from this webpage
Microsoft Hardware
Note the light on the receiver only flashes when you press the 'connect' button. At all other times it is normally out. There usually no lights on the keyboard. You should not need extra drivers as they part of the OS if you are using Windows XP or 7.
If you still have problems see
Your wireless mouse or keyboard does not respond or you receive The...
or search on the internet for our specific case
Dec 05, 2009 | Microsoft Wireless Optical Desktop 700 v2...
Optical mouse no longer works
I doubt the problem is the battery, and you do NOT have to press the Connect button each time you use the mouse - it will connect all by itself if it can. The Connect button is only used to re-establish connection if for some reason it cannot connect automatically.
I have this same mouse and it has worked beautifully for two years now EXCEPT for one problem: most of the time, the mouse does not turn on when the receiver is removed from the receptacle on the bottom of the mouse. There is a tiny little switch built into that receptacle, along the side wall of the receptacle not far from the light, so that it gets pressed when the receiver is inside the receptacle. I have to wiggle this little switch (gently!) by hand a few times until the light comes on. From that point, the mouse will work fine until the receiver is placed back in the receptacle.
Nov 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have the microsoft wireless mouse and keyboard, was working fine, i cant get it to connect now. i need help
there are three reset buttons one on the bottom of the mouse and one on your keyboard's
backside and there is a reset button on the receiver that plugs into the USB press all at once
untill lights flash and try to get it to connect again.
or try to
1- use "Reset" (in you case it might be "Connect") buttons on your keyboard's
backside and also on receiver.
2-use "Reset" (in you case it might be "Connect") buttons on your mous's
Oct 01, 2009 | Microsoft Wireless Optical Desktop Comfort...
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
WIRELESS KEYBOARD caps and niumber lock status
The MS Keyboards and Mice 700 v2 receiver has a reset Button under the word "Microsoft" press this button and then while its flashing press the connect button under the mouse! ALL Fixed
Mar 20, 2009 | Computers & Internet
Microsoft wireless mouse 700 works, slows, then stops
Seems like new batteries did the trick. Should start simple.
But I am not totally convinced. I will keep an eye on it.
Feb 17, 2009 | Microsoft Wireless Optical Mouse
Wireless keyboard locked
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Aug 26, 2008 | Logitech LX 700 9674180101
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
Microsoft Wireless Optical Desktop Comfort Edition Logo
172 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
