SOURCE: battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
SOURCE: Cannot recharge camera
I didn't really solve the "problem". I plugged the charger into a different electrical outlet and PRESTO, the camera began to charge. The outlet I had been using, malfunctioned and had to be replaced.
Easy solution this time.
SOURCE: camera power not coming on
READ AND HEED THE SAFETY DISCLAIMER BELOW!
THE ONE I BOUGHT TO GET THE CD WOULDN'T TURN ON. EXPERIENCE TOLD ME THAT IF I OPERATED THE POWER SWITCH MANY TIMES, IT MIGHT CLEAN THE CONTACTS AND TURN ON. IF THAT DIDN'T WORK AFTER 200 TRIES, I WOULD POUR SOME RONSON CIGARETTE LIGHTER FLUID INTO THE CAMERA BATTERY COMPARTMENT, TILT THE CAMERA SO IT PUDDLED IN THE SWITCH AREA AND TRY AN OTHER 200 TIMES. IN THIS CASE, IT TURNED ON ON THE 83DR TRY, DRY, AND IS WORKING FINE.
FOR SAFETY, IF USING THE LIGHTER FLUID, LEAVE THE BATTERIES OUT, AND NO POWER ADAPTER PLUGGED IN TO AVOID POSSIBLE IGNITION. MAKE SURE THE CAMERA IS DRY BEFORE APPLYING POWER.
SOURCE: My Fuji Finepix S2pro wont turn on
try getting new batteries.. sometimes the rechargable ones just lose the charge.. instead of rechargables try using throw aways. you can try and contact fuji but like myself and others they will just give you 5 differant numbers to call and the problem will not be solved
SOURCE: Fuji Finepix S3500 camera not recognising fully charged batteries
get a new camera sorry thats an old thing when it runs out its out sorry
