I have a Durabook that has worked Flawless up till today! It would not turn on. I tried the suggestion of unplugging the power cord, then take out the Battery, and remove the remory cover. Then I gently took out the memory and put it back in several times to enhance the connection if that happened to be the issue. I even took the hard drive out and back in carefully just for good measures. Then I put it all back together and pressed the power switch. The first two lights on the far left, came on when I touched the power switch as well as the fans. They stayed on for a few moments then back off. Fans were still running. I tried it two more times with the memory and met with the same results as before. Worked great last night and was left on the desk over night.
  • Dusty D Jul 11, 2008
    The modle number is R-15D They only give a one year warrenty and I have had it almost 2 years now. We have a guy here in town I trust, and the gent that sold me the unit is in contact with me weekly. Not a problem to take it in, was looking for some things I could try tonight. I use my Durabook often and this was unexpected. Do you have any thoughts I can try?
    Brigadier General:
  • 6,966 Answers
Pls try powering off, remove the battery and let it be for a while (an hour or so). Thereafter, try without the battery and using the AC adapter/charger only. Another is to try and charge the battery at least overnight with the laptop off.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 11, 2008
  • 4,472 Answers
What is the exact model of the unit? How long ago was it purchased? If it is under warranty you may want to go that route, or have the unit serviced by a qualified technician in your area. If you give me your location I can assist you in finding one.
Hope this helps.
Thanks,
Lee
  • Lee A.
    Lee A. Jul 11, 2008
    yes do it try it with and without the battery and with/without AC, though I believe you stated you tried these things. That is mostly all you can do make sure your contacts are good. Beyond that there is not too many things you can do besides those basic troubleshooting. You would have to start taking the laptop apart to inspect/test other components. Let me know what your guy finds. I hope you found this helpful.
    Thanks,
    Lee
My Pfaff Tiptronic 6270 does not sew.
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
Pfaff Tiptronic 6270 just stopped working
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Sep 05, 2015 | Sewing Machines
I bought a Bamboo Splash a while back, and it had been working fine up until today. I sometimes unplug my tablet and use the cord to charge my phone. Today when i disconnected my phone and put the cord...
Unplugging the tablet would not hurt it in anyway. A power surge can cause such a problem though. Typically the problem you are describing is caused by bad flash memory which is what all tablets use and run on Like a....Example: A Solid State Drive "SSD"
Nov 09, 2013 | Wacom Bamboo Splash Pen Tablet
Memorex MVD2042 Unit worked fine yesterday, but today is not functioning. Standby light does not come on, and no functions work. The unit is receiving power (not an issue with the cord or power supply). I...
unplug from any power source. leave unplug for 15 minutes some capacitors keep power for a while so leave it unplug for a while. then turn back on. see what happens.
Oct 19, 2013 | Televison & Video
My wii won't turn on and I tried unplugging and disconnecting all the cords and it still won't work...any suggestions???
First verify the outlet on wall you are plugging the Wii into works.
Unplug the power cord from Wii AND the wall to allow proper discharge of the power unit. If you do not unplug from wall outlet to then the power unit will not discharge.
It could take up to 15-30 minutes sometimes.
Mar 01, 2011 | Nintendo Wii Console
I have a RCA RP3013 for Christmas, and it was working great till today, now the call numbers are all wacky on the radio and it won't play my CD's HELP!!!
This indicates a massive failure in the processor controller ic, the only thing you can try, unplug the power cord from the receptacle and leave overnight in an attempt to reset the processor. If this fails and there is no change it must go back where it was purchased for exchange.
Jan 09, 2011 | Audio Players & Recorders
I came home today to find that my desktop was off after being previously on earlier when I left the house this morning. I went to turn it on and nothing happened. I got down next to the machine and tried...
>This may not be a resolution but it's worth giving it a try: ?
>Unplug power cord from both the computer and the power outlet
>Press and hold power button down for approximately 20-30 seconds(this is what we call Power Drain: it gets rid of electrical charges on the motherboard which may cause these kind of problems)
>after 20-30 seconds plug the power cord back into the computer
>Turn it back ON
>I really do hope this works
>comments suggestions ratings and violent reactions will be greatly appreciated
Sep 23, 2010 | Gateway Computers & Internet
Wii will not turn on... everything is plugged in and it worked fine last night but there is nothing today
Try unpluging the power cord from the wii and the wall for 5 mins to reset the brick on the cord.
Dec 11, 2009 | Nintendo Wii Console
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
May 26, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
