Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Crtl key not working. Possible due to moisture?
My left ctrl key suddenly stopped working. It has been raining here lots since last week and i kept my laptop in an open room last night. Is it possible due to the moisture its not working. Also, if that is the case then what can i do to get it working?
    Champion:
  • 207 Answers
If u feel the moisture is the case put ur laptop under 500watt bulb in a shut down mode...like under a lamp or so
other wise chk th manuls open the keybrd panel and clean the key properly
Posted on Jul 31, 2008
Flashing engine light on ford freestar,engine is running very rough at higher rpm
A flashing engine light usually indicates a misfire or several misfires. If the ignition components (coils, wires, distributors...) some how become exposed to moisture it is possible to get a rough running engine due to misfire(s) cause by arcking.
Feb 20, 2013 | 2005 Ford Freestar
Headlights won't turn on in my 1999 ford mustang gt
Sounds as though you have an exposed electrical connection that's either getting splashed from the tires, or the moisture is creating a temporary disconnection. This can happen, but once it dries it will resume working. I would have your electrical system checked. I would also have your headlight switch checked for a possible short.
May 08, 2012 | Ford Mustang Cars & Trucks
How do i get my laptop screen thr right way up i pressed somthing and its gone upside down
You probably flipped the screen orientation (rotated it).
For some versions of Windows (XP and Vista), try pressing Control (Crtl)+Alt+Up arrow (press the three keys together). You can also try the other arrow keys with the Crtl+Alt keys. The Crtl and alt keys are both usually in the row with the space bar. On a full-size keyboard, there are two Ctrl keys on the ends of the row and the alt keys are closest to the space bar.
Otherwise, right click on the Desktop (where there are no programs or icons) and choose Graphics Options > Rotation. Another place to check is right click on the desktop and choose Screen Resolution > Orientation. This is a shortcut to accessing the display properties in the Control Panel. Click Start > Control Panel > Appearance and Personalization > Display > Screen Resolution. For a widescreen monitor, choose Landscape.
I hope this helps.
(The ctrl+alt+arrow key doesn't work on my Win7 desktop but does work on the laptop. The Orientation change from the control panel works on both.)
May 04, 2012 | Acer Computers & Internet
I get a pop window saying CONTRAST 100 .This comes every time . what should i do to stop this pop up window ? is this due to virus?
This problem is probably related to dust/moisture or a stucked sticky control key on your monitor. Perhaps the contrast button is stucked - press the button a few times to try and release it or use a hair dryer/dry compress air to blow the keys if it is due to moisture. (Happens during raining seasons).
Hope it helps.
Nov 11, 2010 | Computers & Internet
Hello Experts, I want to do move/copy multiple files files from one folder to another. eg: I received some 10 files through bluetooth and i want to select 8 of them and move it another folder. I...
Press Ctrl key and select as many items you want to after selecting it just press Ctrl+C keys to copy it and go to destination drive/folder and press Ctrl+V keys to paste them.
For any further help mail on mu email ejaz89@live.com
Aug 23, 2010 | Computers & Internet
Cut or copy and paste does not work
That is very common problem and there is no one-best-sollution for it since they are tons of possible reasons.
Possible sollutions:
#1 close all programs
#2 switch off->switch ON pc
#3 scan for possible malware using antivirus software
#4 try using keyboard shortcuts crtl+c = copy or ctrl-x = cut
Leave rate if I helped you, thanks!!
Cheers,
Mike
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
Igniter Stopped working
Igniter could be shot. Take out igniter and put near something metal. Push button to see if sparks occur. If not igniter is no good. If this works, the end of wire that is near wear the igniter sparks to light grill could be to far away from metal, bend to get closer to metal, so it will spark, or end could be covered with grease, clean end and try for spark again.
Jun 14, 2009 | Weber Performer Grill
How to deactivate internal keyboard - Dell Inspiron 9400
if you go to the control panel, to hardware, in the keyboard section you should be able to uninstall the internal keyboards driver which will stop it working.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Key pad
If you can not use your Ctrl, alt delete keeys before the operating system loaads, then your motherboard is the problem. Replace the mainboard, and this issue will go away. Many of these units have this same issue. However, if you can use them before the operating system loads, then reload your os or attempt to repair it using your installation cd. To use the keys before the os loads, right after the dell logo appears, immediatly hit crtl alt delete. and your system should respond. LePro DCSE
Nov 22, 2008 | Dell Latitude D600 Notebook
Computer gone on the fritze
did you get moisture in the control panel like it got rained on or while cleaning it it may need to dry out for a week
May 09, 2007 | Whirlpool RF368 Electric Kitchen Range
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
80 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
