Dryers Logo
pat Posted on Jul 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Creda condenser dryer
It is only blowing cold air can anyone advise thanks.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1134
Points
Change the two sensors on the back of the machine
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Jul 11, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898703
Points
3964
Remove the back plate and check the heater and stats. probaby the stat open circuit
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2011 • Dryers
Our tumble dryer is not blowing hot air only cold wot could the problem be ? its a creda simplicity condenser dryer - tc 22 cw
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
My Creda Excel T323vw dryer is only blowing cold air ?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 • Dryers
I'm only getting cold air blowing out condenser
you need to call a techincian sound like your heater element when out are if this is a gas dryer your glow bar are your gas coil when out,sorry
Apr 24, 2010 • Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 • Dryers
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Hi - i have a creda TVR2 Dryer - the pipe although placed through a window was full of water and now the dryer will not heat
The hose may be partially blocked, stopping the air from blowing through properly,check that there is no bend and that the hose is not sagging down as this causes the moisture laden air to condense inside the hose and create water build up.
The water has probably caused the thermostat or heater to fail.
To check the element and stat(s) you need to remove the rear panel of the dryer, and tyest with a meter.
Plz rate my solution.
Thanks.
Jan 04, 2009 • Dryers
3answers
A Creda condenser dryer TCR2, it went off won't work at all now
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Thanks.
Creda t601cw condenser dryer
hi sounds like your belt has snapped or drum has snapped from the shaft regards jason
Top Dryers Experts
john h
