Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS 1397W
The pump appeared to get stuck, it sounds like a small obstruction in it, how do i fix this??? Should i get a repair man or is this a easy diy???
Zanussi 1250. WJS 1397W. TurboDry. Jetsystem Excel. RSI, Rinse Sensor Injection These pages are about how to fit the door seal on a Zanussi 1250. WJS 1397W. TurboDry
http://www.agreatportal.com/zanussi_1250/index.html
These pages may help you.
Posted on Aug 18, 2008
    President:
  • 1,462 Answers
Possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Posted on Jul 11, 2008
Hi I have a zanussi Jet system FJS 1397W washing machine, the problem with it is that, the drum does not spin round any more- What is likely cause? thanks
hi check the pump first it has to drain before it spins the other cause could be the module control board the control the motor speed hope it helps
regards
shaun
May 27, 2011 | Zanussi FJS1225W Front Load Washer
Changing drain hosezanussi w1242w
It clips onto the pump , you undo the clip remove hose refit and reclip same checking for any leaks before running machine, its very simple to do .....
Apr 13, 2010 | Zanussi W1242W Front Load Washer
My zanussi washer dryer wjs 1397 w drum is not turning
It is most likely that the drive belt is broken and needs repalcing, If you remove the rear panel it will be obvious if it has broken *** there will be a lrge flywheel attached to the drum and no drive belt going to the motor, near the bottom of the machine. These are easy to obtain from any domestic appliance spares store or mail order. They are also very easy to fit.If the drive belt is in place and is reasonably tight (taught) then you may have an issue with the motor. clutch or brake.
Oct 12, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Wjs 1397W. The water goes in OK. The
It was a bad joint on the motor control board. It was well burnt on one of the relay connections. I assume that the machine senses when the drive starts and then stops before changing the relays. Of couirse it only wend in one direction and was waiting for it to go in the opposite one before proceeding.
Jul 09, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Settings dial has broken on my Zanussi WJS - 1397W
You can go to this site and find/order the parts to fix it. It looks like the top of the machine just pops off (held down by clips) which then exposes the control panel and allows access to fix. Hope this helps.
http://www.espares.co.uk/diagram/washing-machines/zanussi/wjs1397w/p/1085/332/0/407647?ed=3912
Oct 27, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
How do I fit a new door gasket?
after putting the seal on with the aid of washing up liquid put the spring on first by the door catch hold it on with one hand and isnert a screwdriver in the hole for the door catch this will enable you to hold the spring on if you put your knee against the screwdriver giving you two hands free to push the spring on
Aug 04, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
410 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
